Question about Asko W620
My Asko W620 washer won't spin the first time through.
Hello, I am having problems with my washer (Asko W620) not spinning out the closthes the first time through. Every time I wash closthes it runs through the whole cycle except the spin cycle and it stops on the C. It spins fine if I just run it through the spin cycle again. Someone gave me the washer and dryer so I don't have a manual and I am having trouble figuring it out. Can anyone help??
Thanks
    Top Expert:
  • Asko Master
  • 34,089 Answers
Try Googling (asko)(W620)(manual) without parens.
Posted on Jul 22, 2017
5 Suggested Answers
  • 3 Answers
SOURCE: Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Posted on Jan 21, 2008
SOURCE: Asko 620 washing machine keeps filling
Sounds like your fill solenoid has stuck in the open position. There are 3 #20 Torx fittings along the back and you can lift off the top panel. The solenoid will be in the back left side.
I would shut off your house water supply to the machine and then do a voltage check to see if the solenoid is remaining energized. Another more simple option is to give the device a few light taps as some debris may have become trapped inside and caused it to become stuck open.
Posted on Jul 27, 2008
  • 3 Answers
SOURCE: asko front loader washer w620
Check your motor brushes. They may need to be replaced.
Posted on Aug 05, 2008
  • 8404 Answers
SOURCE: I need new motor (spin) for W620 that is 8 years
Nope
Posted on Oct 27, 2009
Asko w620 washer will not agitate or spin
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Nov 24, 2013 | Asko Washing Machines
My asko w6200 won't start .I checked the fuse and everything is ok. what should i do next?
Hello Alain, welcome to FixYa.
May I ask which fuse you refer to when mentioning you have indeed "checked the fuse" ? Are you alluding to the fuses at the back of the washer ? Let me know and I'll try to assist you in any manner I can going forward.
Regards,
Macmarkus :)
Oct 16, 2011 | Asko W620
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Water inlet valve problems
repairclinic.com has parts available.
Jul 31, 2008 | Asko W620
Asko 620 not spinning and not agitating
Clean armature and replace brushes. When you remove the brushes the shut a small pin like device maybe protruding from the brush tip. this is a sure clue.
Jun 18, 2008 | Asko W620
Asko front loader washer w620
Apr 19, 2008 | Asko W620
Noise
Probably the drum spider has gone loose from the drum. You need a new drum to fix this problem.
Good luck
Jan 07, 2008 | Asko W620
Dec 11, 2007 | Asko W620
Washing Machines Logo
96 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
