Question about GE DBXR463EBWW Electric Dryer
Dryer runs but will not heat up.How to locate the the thermostats to replace them?
    Genius:
  • 1,122 Answers
The thermostats are under the lid on the back right wall,most lips just pop off useing a putty knife in the front seam,one on each side,before replacing test with omhs meter to make sure it's not your heater coil,let me know how you do-mike
Posted on Oct 15, 2008
My maytag lde8824ace dryer has stopped heating. i replaced the heat element assembly about an hour ago and still no heat. vents and ducting are clear. dryer run as normal. was wondering if it was a...
The heating circuit is composed not just by the heating element alone but also the high-limit thermostat located on the heating element housing including the four-terminal cycling thermostat on the blower housing and the motor centrifugal switch. The most prudent thing to do first when a heating problem is experienced is by checking the continuity of these parts and making sure the dryer is getting 220VAC supply. Note that the dryer works both on 110VAC for the controls and drive motor while the 220VAC is solely for the heating circuit. The 110VAC supply may be present which will make the dryer run but the 220VAC may not be present and consequently there's no heat at all.
Check the circuit breaker including the power outlet and make sure the dryer is being supplied with 220VAC. Check the continuity of the components located on the blower housing and the heating element housing. All of those components must have continuity for the heating element to turn on. Note that the cycling thermostat has four terminals. Continuity check must be done between the two outer and "thick" terminals. Replace the part found to have no continuity and as a preventive measure, it is necessary to also replace the other part that comes side-by-side with the faulty part.
Aug 21, 2011 | Dryers
I have an older Kenmore gas dryer model # 97260100 it heats up for 15 minutes then goes cold, drum continues to run can u give me any insight as to what needs to be replaced
The problem is either of the cycling thermostat, high-limit thermostat or the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify any of these condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
Nov 08, 2010 | Kenmore 72872 Gas Dryer
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
My dryer will run, but will not heat.
Hello there
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
Thermal Fuse
Thermostat
Timer motor
Jan 25, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer runs but does not heat replaced the heating element a few months ago and fuses breaker box is good
hello there:
Please follow this troubleshooting guide that i will provide below
My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
Proper Voltage
Heating Element
Thermal Fuse
Thermostat
Timer motor
function isValidEmail() { var emailAdd; emailAdd = document.all.infobar_EmailAdd.value; if(emailAdd == "" || emailAdd.indexOf("@")
Jan 25, 2010 | Dryers
Will run but won't heat
HELLO THERE
There are 5 things that can make a dryer not heat please review the following items that i have provided for you
investigate these five areas if your dryer is not heating up:
Proper Voltage
Jan 18, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer will not heat
Hello there:
There are 5 things that would not make the dryer heat up i will post you them here ok
Jan 17, 2010 | Dryers
The dryer runs but does not have any heat. I
Start by hooking each of the thermostat wires together to bypass . When dryer starts heating, you have located the defective one.
Nov 08, 2009 | Dryers
How do I get to the thermal fuse on Whirlpool electric dryer LER4634EQ0
All the heating and temperature control components are located in the back of the dryer. To access, unplug the dryer and remove the exhaust vent hose. Turn the the dryer around so you can view the back and remove the back panel. With the panel removed, the component locations are as follows:
Right-Hand Side:
1. Heating element - located inside the heater box. If bad, the dryer will run, but will not heat. A good reading is about 9 to 13 ohms.
2. Thermal Cut-Out (TCO) - located on the outside of the heater box on the end opposite the heating element terminals. If bad, the dryer will run, but will not heat. A good reading is a short (0 ohms).
3. Hi-Limit Thermostat - located on the outside of the heater box adjacent to the heating element terminals. It works in conjunction with the TCO to help regulate the drum internal temperature. A good reading is a short (0 ohms).
NOTE: If either the TCO or Hi-Limit Thermostat are found to be defective, it is recommended that you replace BOTH components to prevent premature failure. These two components are commonly sold as a set.
Left-Hand Side:
1. Thermal Fuse - located on the blower fan housing. It is a small white plastic looking component with two wires attached. If defective, the dryer will not run at all. If the component is good it should read a short (0 ohms).
2. Internal Bias Thermostat - located on the blower fan housing adjacent to the Thermal Fuse. It has four wires attached to it.
NOTE: All resistance checks should be performed with the component terminal wires disconnected to prevent false readings.
If you have any questions, you can refer to searspartsdirect.com for some helpful exploded view diagrams to assist you. The components I mention are listed under the "Bulkhead" heading as follows:
Item 6 - TCO/Hi-Limit Thermostat replacement kit
Item 15 - Hi-Limit Thermostat sold separately
Item 17 - Heating Element
Item 23 - Thermal Fuse
Item 24 - Internal Bias Thermostat
If you need further assistance, please let me know. I hope this helps you.
Sep 23, 2009 | Dryers
Dryer does not get hot
pleas4e help my dryer is working but it won't get hot it just blows cold air please help me fix this problem
Jul 20, 2007 | LG DLE0332 Gas Dryer
GE DBXR463EBWW Electric Dryer Logo
54 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a GE Dryer Expert? Answer questions, earn points and help others
