Question about RCA F31672ET TV
No sound i was recently given rca 32in tv model num f31672ET. The sound is not working do you have any suggestions on how to fix this or how much it may cost
  • danz1234 Dec 20, 2008
    i have the same problem , but i think i know the solution.
    I checked the speakers seems fine i have a suspect its the TDA7263
    audio amp.I try this fix and let you know.
  • Cortez Potts
    Cortez Potts Mar 13, 2009
    hey did it work?
  • RCA Master
  • 1,216 Answers
Clip R1915 and the sound will return. But you still have a Tuner to rework. See my solution with the power problem. just before this answer!
Posted on Apr 29, 2010
Can i use my RCA F31672ET TV as projecter for my computer? I cant find any HDMI port.
Not possible as model listed is composite video only with two additional inputs for audio--no way I know you could do this.
Mar 20, 2012 | RCA F31672ET TV
I have an RCA F31672ET TV. It was working fine for many years. Then all of the sudden it will not turn on with either the remote or the power button. I thought of using a universal remote to try and turn...
Hi - pretty common problem. Not worth fixing, I'm afraid. It is caused by a defective circuit which became defective with old age. the "EEPROM."
Feb 27, 2011 | RCA F31672ET TV
Rca 32in TV Product serial#f483ceok5 RCA 32in
try unplugging the tv from all imputs and power and let set over night then plug everything back in.
Feb 10, 2011 | RCA TruFlat 27F520T 27" TV
I have a rca tv model F31672ET. I do not have the
Check with the channel 00 good luck
Jun 05, 2009 | RCA F31672ET TV
RCA MODEL F31672ET
You have a Tuner on Board that needs reworked. You must remove the bottom shield and resolder about 20 points. As for the sound problem you may by now have a bad eeprom [location U3201]. We may be out of Horizontal Frequency as well. First fix the tuner then replace the eeprom.[Iwould install an eight pin IC socket upon removal of eeprom, then you can insert or remove the new eeprom anytime after this]. And also check capacitors C4404 200V at 2.2MF, C4105 200V 10MF Will be bad in this case, C4127 and C4709 these may be weak. This shuld repair your TV. PS the eeprom part# is 223957. Before you change the eeprom see if you can get a good picture after resoldering the Tuner. This is delicate work so be careful or you will destroy the TV. If you do have a good video and no sound, clip R1915, this will defeat the mute,but sound will return. Just so you know repairing this TV is quite complicated good luck.
Dec 23, 2008 | RCA F31672ET TV
RCA F31672ET TV
use tv/video switch
May 03, 2008 | RCA F31672ET TV
My rca tv
a high pitch sound.. usally indicates a shorted horizontal transistor or possibley a flyback or both. common problem for this set
Dec 10, 2007 | RCA F31672ET TV
RCA F36676ETFM2
it sounds me that it is due to cable wire connection where it is connected is probably might be loose or if you have cable box there is some loose connection.
Oct 05, 2007 | RCA F31672ET TV
RCA F31672ET No Power only a whining noise when plugged in Please help
Most likely you have a bad flyback transformer and shorted horizontal output transistor. The whistling sound that you hear is the power supply telling you that it has a short in one of the circuits it powers. Most likely the circuit mentioned above. Stargazer
Mar 06, 2007 | RCA F31672ET TV
Televison & Video Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
