Question about HP DesignJet 500ps InkJet Printer
Print Orientation issues
We typically print 24x36 sheets but also from time to time print 18x24 sheets; however, when printing 18x24 the page always prints out 24x24 square and needs to br trimmed to size. It used to print out correctly but we haven't found out what the setting is to fix it. We'd like to print the 18x24 size in the rotated orientation so we do not need to trim the paper. Can you help us fix this?
Thank you.
jennifer@LK-architects.com
I had the same trouble but found that if i set the printer setting on "horizontal" for 18 x 24 (with a 24" roll of paper) and "vertical" for the 24 x 36 it worked the way I wanted. Hope that helps.
Posted on Mar 31, 2009
While on a call with HP support, they told me to go back to driver version 6.17 from 6.19.
Posted on Mar 18, 2009
  • HP Expert
  • 141 Answers
Find autorotate in the driver. find paper settings, more sizes, arch b, then pick that for those smaller plots. Good Luck!
Posted on Nov 01, 2008
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Apr 19, 2015 | Konica Minolta bizhub C250 All-In-One...
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
Brother 465 cn printer. When printing test sheet, only 3 black boxes show up. For each color 20 to 30 boxes show up. Is this caused by a bad print head? How hard is it to replace the print head? Are...
I am having the exact same problem. just 2 squares on first line and first square on the second line. I have replaced the black cartridge 3 times and cleaned it many times. But get the same test print page result. Any suggestion for fixing this problem?
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
The printing goes off the page
pls set the paper size to the actual paper size you load.. you have probably selected legal size in your pc and load an A4 size paper onto the printer...
May 26, 2010 | Epson LQ 300+ Matrix Printer
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
The HP All-in-One prints a print cartridge alignment sheet.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
Enlarge and print pictures with a lexmark 6675
You can expand your image to multiple pages, so you can stretch an 8.5x11 image to close to 18x24, by selecting Poster (in the copy menu), and 2x2.
Mar 20, 2009 | Lexmark X6675 Pro Colour Wireless...
Laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Mar 07, 2009 | HP LaserJet 3015 All-In-One Printer
HP laserjet 3050 prints skewed vertically
250-sheet input tray (tray 1)
The input tray holds up to 250 pages of 80 g/m2 or 20 lb paper or fewer pages of heavier media
(25 mm (0.9 inch) or less stack height). Load media with the top forward and the side to be printed
facing down. To prevent jams and skewing, always adjust the side and rear media guides.
NOTE When you add new media, make sure that you remove all of the media from the input
tray and straighten the stack of new media. This helps to prevent multiple sheets of media
from feeding into the all-in-one, which can cause jams.
Hope this helps if not you may have a registration roller problem.
Dec 15, 2008 | HP LaserJet 3050 All-In-One Printer
Printer won't stop jamming
sounds like your printer wants to form it's own three piece band(kidding here).
sounds like you rollers are dirty or have something on one or both of them..like tires on a slippery road, these need to be clean and dry.
Mar 08, 2008 | Samsung CLP-600N Laser Printer
MY test page always prints
I belive that after replacing the INk cartridges, you are experiancing this problem. The Alignment test sheet always prints everytime you turn on the printer, if u haven't completed the Alignment process.
To complete the Alignment process,
>>Once the printer finished printing the Alignmnet test sheet.
>> Place the Test sheet staright on the scanner glass facing down towards right hand corner.
>>Press the scan button(color), the Power ON light will start flashing, wait until it stops flashing.
>>Alignmnet process completed.
Thank You
Feb 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP DesignJet 500ps InkJet Printer Logo
197 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
