Question about Miele Cat & Dog 326i Bagged Canister Vacuum
Water was sucked into Miele Vacuum
I think my husband sucked up a bunch of water into the vacuum and it slowly just shut itelf off and now wont come back on. I briefly smelt some burning, so Im assuming the water is causing the problem. I just hope it's fixable????
  • 125 Answers
The motor is shot.they cant handle water. you are looking at a very expensive repair. miele parts are about the most expensive around. next time look at a panasonic, or riccar. or for a lifetime vac, look at the Metropolitan, made in the USA(around $400)
Posted on Jan 26, 2009
  • Demonic-2011
    Demonic-2011 Feb 26, 2011
    Throw it away - water would have corroded the insulation and/or motor windings - resulting in a live short. Not worth repairing or risking your life with it. Buy a new vacuum.
It wont suck the water back up
You are not suppose to suck water with an ordinary vacuum. If its a shop vac yes. Otherwise you will ruin it.
Jan 06, 2017 | Vacuums
My shark proffesional nv502 vacuum wont power on. My daughter sucked up a sock and it shut down to avoid overheating the motor I guess. Well--3 days later andit still wont turn back on. Is there a reset...
it should start after awhile is it the whole machine or just the brush bar. oh there is no reset from what i read.over heat motor it shuts down till it cools.
Feb 08, 2015 | Shark Rotator Professional Lift-Away...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Is it possible to vacume water with the miele slaris turbo plus?
I wouldn\'t attempt that unless it says you can do that in the manual. Use a steam cleaner. They are made to suck up water.
May 18, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
Steam coming out of Miele S7000 upright vacuum cleaner
There is no steam generator on your Miele. It can only be smoke or dust. Are you certain it is steam. If you have sucked up water the motor could be in danger of shorting out.
Aug 12, 2013 | Miele Vacuums
Vacuum sucked up a sock through the hose- now it's clogged how do I fix it upright vacuum
Best thing you can try is getting a "snake" like for unclogging water pipes. Start at where it went in, the hose is behind the brush roll, just off to one side. Gently push the snake in until you feel the scock and twist the snake while pulling it out; if nothing comes out after a few attempts, try a reverse approach by removing the rear parallelogram looking port on the back rear of the vacuum. There are 2 plastic screws which only have to make about a quarter turn. Gently lift the cover off the port and try the snake down the left channel.
Jan 24, 2011 | Miele S7210 Bagged Upright Vacuum
My husband sucked up part of a rug. The belt didn't shut off like I thought it was supposed to. Now there is a funny loud hum when the brush is running. There are also some fuzzy disc-like things around...
See if you can take the brush assembly off. There should be a plate and 2 screws. One on each side. You can lift out the brush and get all of the strings and such off of the roller brush. You might have to go a little deeper with it open and see if anything got sucked up the vent way.
Jan 06, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
My steam cleaner wont pick up water i have checked everything and its fine but still isnt sucking up water
Well Sexy mama ..are there any on~board screens that require clearing? Pet hair clogging up vac wand end? Is there vacuum power for attachment hose? Also, check that the wand /attachment switch is to vacuum and not set for attachments. Good luck !
Apr 30, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Miele Cat & Dog 326i Bagged Canister Vacuum Logo
919 people viewed this question
Top Miele Vacuums Experts
Ryan S
Ryan S
Roger Potts
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
