Question about Brother HL 5250DN Laser Printer
Will not print
This printer's "cartridge light" is on to indicate it needs to be refilled but we have a new cartridge in in and have been printing for a couple of days now with no issue. Now it will not print. Any suggestions?
Thanks,
Although the toner cartridge we used was listed as compatible it was a universal cartridge and when replaced with a Brother cartridge the machine began printing and the error indicator light went back to normal. All is well.
Posted on Oct 15, 2008
Just changed cartridges to refills and clour and black lights flashinghowever we can still print ok. Why are the lights flashing?
The lights are flashing because you are using refilled cartridges. The printer "sees" those cartridges as empty, since it can not know that someone has refilled them. When you put in new cartridges, the lights will stop flashing.
Just ignore the lights and print!
Hope that helps!
May 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have HP 6540 ...... the black cartridge was emptry ( my son do this :) ) ...when i refill it (and put it in the printer) indicator says that the cartridge is empty. When i pres the buttons on the printer...
each cartridge has its unique serial number,
printer remembers him,
is absent sensor of the ink level determination in you cartridge. You can to print, but message will say to you "EMPTY CARTRIGE".
this warning function can be disconnected by you in printing driver.
If you bathe new cartridge, that level will show full.
If afterwards put(deliver) old , that he will show that empty.
Printer can have a memory about two or three last cartridges.
Dec 17, 2009 | HP DeskJet 6540 InkJet Printer
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Light print problem in sumsung 2010
it is problem your cartridge unite toner powder not support toner supply brush
you change cartridge and buy a new one then solve it
Sep 05, 2009 | Samsung ML 2010 Laser Printer
I put new ink in my hp F4280 printer and I printed about 100 sheets and my light turned orange and it started printing slow. Can you tell does it need new ink already?
The ink level indicator is only an estimate. See page 72 of the user manual which you can obtain here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
The HP 60 holds enough ink to print approximately 200 pgs. By the way, it also can evaporate from the cartridge quickly too so try to keep a refill kit or new cartridge on hand.
Jun 08, 2009 | HP DeskJet F4280 All In One Printer InkJet
Light on. Exclamation mark within a triangle. Printing fine and clear. What does tis symbol mean?
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
May 21, 2009 | Samsung ML-2510 Laser Printer
Indicator light remains lit even though it is a full cartridge
It seems there are "new" chips & "old" chips in these ink cartridges for the HP 1200 inkjet printer. I have a cartridge with a "new" chip in and it is working fine. The printer doesn't read the "old" chips. Something to watch for when using refilled ink cartridges.
Apr 17, 2009 | HP Office Equipment & Supplies
Deskjet printer cartridge problem - won't print
I was having the same problem and just posted it, went back to my printer, put the old cartriage back in and printed, I am taking the refilled cartriage back to walgreens where I had it filled and buying a new/hp cartriage to install.
Mar 17, 2009 | HP DeskJet F380 All-In-One Printer
I have a new canon mp210 printer ink is low i bought new ink to replace old their is no ink cartridges in printer. When i look at the pictures to load new ink and put it in alarm light is flashing
Even if the ink level is low, you can continue printing.Press the paperfeed knob for 5 seconds. inklevel indicator will stop now.
Sometimes a new (or refilled) cartridge is not recognised correctly.
When one color is really mt, stop printing and replace inmideatly the colorcartridge.Printing or scanning without the 2 cartridges in place is impossible.
Dec 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Brother HL 5250DN Laser Printer Logo
59 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
