Question about Whirlpool LER7646E Dryer
Ler7646dQ0 dryer runs only for 2o mins; won't run or start in other positions
My whirlpool dryer runs only for 20 minutes. It won't start or run in other positions. Less than 60 days ago I replaced thermal fuse, thermostats (2), element, and on/off switch. This is an LER7646DQ0 (or LER7646DQO ).
  • 188 Answers
Hopefully it's been already mentioned or looked at but check your vent to the outside. Make sure it's not kinked or blocked up with lint. Don't forget to check the outside too!
Posted on Feb 17, 2009
CAR WON'T START AFTER CHANGING BATTERY
it is in theft mode. you will need to turn the ignition to the run position and the theft light will blink. leave on for about 15 min. turn key off then turn back to run position without trying to start it. leave in run position fo another 15 min. turn off then try to start. should start
Jun 13, 2012 | 2005 Saturn ION
Whirlpool 6 cycle dryer keeps shutting off. it will start back up and run, sometimes it will finish the load and most times it will shut back off in 5 to 20 min.
vent is restricted, disconnect vent tube run dryer. Clean out your restricted vent tube with a leaf blower and make sure it is not kinked or too long, this should help Tim:
http://www.applianceaid.com/general.html#vent
Mar 11, 2011 | Whirlpool Dryers
I have a Whirlpool Dryer model GEW9200LW1. I have to push the start button 10-15 times to get it to start, then it may run 1 second to 20 min and just shut off with time in the display. then if i push...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2010 | Whirlpool Dryers
My dryer a Whirlpool. will run for about 10 to 20 minutes, then cuts off. After about 10 to 20 minutes, I can start the dryer again (push start button) and it will run for another 10-20 minutes. ....This...
there is a hi and a low tempreture sensor best to check those for continuity first when the dryer heats up and gets to hot the hi will turn off the heater where as when the low gets to cool it will turn it back on
hope this helps
Apr 30, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer cuts out about 20 minutes into cycle and then will not start. If it is left to rest for 20 minutes it will start back up and run for 10 to 20 more minutes before cutting out. I...
its getting too hot. Take the panel off the front and take the cover off the blower wheel. It could be packed with lint. vacuum out all the lint that you can get too inside the dryer.
Nov 12, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer runs for 20 minutes. shuts down. won't start again for 2 hours.
Hi, It sounds like you have a motor going bad. If this is a whirlpool brand models, the motor is about $90.00 to $100.00. If I can assist you further, please let me know.
Thanks
Vic
May 21, 2009 | Dryers
Dryers Logo
115 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
