Question about Casio Cameras
I have had the casio excilim today, it has now been on charge for 6 hours and is still flashing red and will not turn on at all. the battery is in the correct position.
  • lisaqm2 Oct 14, 2008
    hi, thanks for advise. i bought the camera off ebay, it did not say it was not from the u.k. how ever it is new. the cables provided are the u.s type and not british. he provided an adaptor but the cradle just flashes red. should it be a steady red light or is it supposed to flash. just wondering if i should just buy new u.k cable.
    thanks in advance, lis
    Master:
  • 383 Answers
Check Battery Voltage ..... IF battery shows correct voltage ... try upgrading your camera firmware
Posted on Oct 14, 2008
I also have Casio Exilim EXZ75 I didn't charged it for almost 3 weeks and once I charged it, the red light flashes on and off... Then I inserted it in the camera... it still doesn't work... how can I solve...
kindly leave the battery for long duration in charging position let the red light blink and then see after like 16 hours or 24 hours if it works and charge otherwise change the battery with the same specs , and next time when u leave battery for long duration likea month or weeks charge it to full or half so it can hold some power to re charge again , ur battery is in Coma state nearly dead so it might come back or not
pls rate me well
Regards
Zohail
Aug 11, 2009 | Casio Cameras
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
When the battery is in the charger it flashes red & won't charge, have no idea what problem is! Have casio exilim lithium ion NP-20 battery & a casio exilim 7.2 megapixels camera. Can't turn camera...
I called casio and they told me that when you have a red flashing light on the charger it means the lithium battery is no longer any good. They offered to send me one free of charge. It's been several weeks and I have yet to receive it.
Jul 08, 2009 | Casio EXILIM Digital Camera
Battery Dont Charge
I had the same problem. I had a 1 year warranty, so I called 1800-435-7732 and they sent me a new battery within 5 days. I just received it today and it works perfectly. Hope this helps you! =]
Dec 26, 2008 | Casio Exilim EX-Z77 Digital Camera
My casio exilim s880 is playing up
Here's what I found and it actually worked after about 7 times. Others said they had to do it about 20 times. Good luck!
ylu1 writes:
what i did was...
hope this helps.
Dec 09, 2008 | Casio Exilim EX-S880 Digital Camera
The battery wont charge
i had the same problem.
if your battery light is blinking a red light then you should call up casio's technical support and they'll send you a new one within 2-5 business days:)
call 1-800-435-7732 for technical support! :)
Apr 01, 2008 | Casio Exilim EX-Z77 Digital Camera
Charge Flashing
the batteries lose their memory and need to be shocked back to life.. Here's the fix:
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Oct 03, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Battery will not charge
I found this while searching to find an answer to solve my problem. It worked! Some say that it took them about 20 times... it took me about 7. Be patient and just keep trying! Hope this helps!
ylu1 writes:
what i did was...
hope this helps.
Sep 06, 2007 | Cameras
Battery and Charger problems
Only a new battery I venture what type of battery is it?
May 26, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Cameras Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
