Question about Technics SA-DA10 Receiver
Technics SA-DA10 jumps into overload after 10 minutes
I turn the reciever on without speakers and volume zero then after 10 min he jumps into overload . I notised that the fan starts to turn when the volume is half way up is this correct ? I would love to hear the sound out of this reciever , i just bought it from someone . Hope the expert's can help me greetings Jan Henk from Delfzijl / Holland
  • 2 more comments
  • hennep Oct 14, 2008
    No not yet i try it now . Sony speakers 200 Watt max 8 ohm.
  • hennep Oct 15, 2008
    I m going to try that one tomorrow . Good one and yes i'm handy whit a soldering iron so lets have a look . could it be caused by thin wires ? i have attaged 2 x 1,5 mm . i think its too thin but don't have any other maybe i should buy new cables ? and wich sise ? 100watt rms per output gr jan henk
  • hennep Mar 12, 2009
    Hello Hennep again . i have checked it but can't see any loose connections . the amplifier works for 2 minutes then it goes into overload . if i turn it on and put up the volume or bass it goes in overload inmediatly . the lights in the volume button and input selector don't work either. What could it be ?
  • Anonymous Mar 16, 2014
    overload with the sa-da10 home theater systeme wene i turne the volume up past a quarter im using 2 pairs of speakers the fan wasent working i replaced it i have the same probleme
I tried stil having the same problem the led in the volume buttun doesn't work the one in the selector button also doesn't work. JH
Posted on Oct 14, 2008
    Scholar:
  • 92 Answers
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
  • Inno Laur Oct 15, 2008
    Sounds like a faulty amplifier. Technics amplifiers use ICs in their output stage and over time the connections can come loose and cause faults like you're seeing.
    If you're handy with a soldering iron or know someone who is, remove the circuit board and check around the output stage (actually look over the whole board) and re-solder any connections that look like there are hairline cracks around the legs of any components. This is very common on Technics amps.
    Don't worry about the size of the speaker wire just yet. Even with undersized wire (as long as it is not too long) you should still get sound out of your speakers. Also make sure that none of the wires are touching each other or to ground.
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Nov 16, 2008 | Technics SA-EX110 Receiver
SA DA -10
If all the speakers are connected proper and it still says "Overload!!!!!"
Your output amplifier module is most likely failed.
Mar 08, 2008 | Technics SA-DA10 Receiver
Technics SA DA20
I have a Technics SA DA20 control receiver. I was given it by an electronics workshop and it has this same error of OVERLOAD coming into the display when switched on. I removed the plates from underneath and re-soldered as far as I could all the points along the stereo amplifier ICs and as far as access would allow. The unit then worked normally for several hours. I was very pleased, and went out shopping!. But on my return after it had been off for about an hour, the same problem has come back. But my boss at the electornics workshop thinks it it just a dry joint, or series of dry joints. The unit is complex to dismantle, so patience and care is required in taking it apart and making a note or diagram of how it comes to pieces and how to re-assemble it after the board has been re-soldered. It does not appear to be a component problem or fault with the SVI power amplifier ICs.
petertaussig33@hotmail.com
Feb 23, 2008 | Technics SA-DA10 Receiver
Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Overload
internal wickman fuses blown check speakers high unts tweeters\ gone short primary transistors /ic blown
Dec 31, 2007 | Technics SA-DX940
Technics SA-DA10 Receiver Logo
1,092 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
