Why do i have to run diagnose connection problem everytime i try to connect to internet
  • 5 Answers
A good starting place - Go to the Windows 'Device Manager' and delete the network card. Reboot your system and windows will auto reinstall it. Setup your IP Address unless its set to DHCP (normal) and all should be good. If that doesn't work then reboot the modem and/or router and clean your network cable connections.
Posted on Oct 14, 2008
Everytime i try to log in it says Internet Explorer cannot display the webpage Most likely causes: You are not connected to the Internet. The website is encountering problems. There might...
change ur browser, clean internet history, internet cache , registry, registry should be cleaned , use reg in out registry cleaner to fix the issue
Sep 13, 2010 | Microsoft Internet Explorer 8
Atfirst we tried to install kaspersky antivirus, as there was no internet connection,the process didn't succeed. Thereafter everytime trial to install the antivirus it is failed. Everytime after typing...
When you use Internet Explorer, can you web-surf to *ANY* pages at all? If not, then your Internet connection is not working.
When your Internet connection is working,
use Add/Remove Programs to uninstall the software.
Restart your computer.
Re-install the software.
Apr 10, 2010 | Kaspersky Labs Antivirus 2010 Full Version...
Trying to connect to internet but screen says internal modem has no driver - it sees no modem
If you're compuer is connected to a router or DSL/Cable modem through Ethernet connection, you don't need to have to use internal modem. Internal modem are just for dial up connection.
If everytime you launch IE browser and it gives you that prompt, your browser may have set up to connect everytime to a dial up connection. Try to check these settings on your IE:
1. Go to Start> Settings> Control Panel> Internet Options
2. On Internet Options, go to Connections tab.
3. Delete everything under Dial Up and Virtual Private Network Settings, Or just set it to 'Never Dial A Connection'.
4. Click on LAN Settings button.
5. On the next window, uncheck everything (particularly the proxy setting).
6. Click OK all the way out.
Oct 23, 2009 | HP Pavilion a1610n PC Desktop
Internet and Network Connection
we had similar problem earlier and unformtualtly we have to install the OS again. you can first check you firewall setting, try disabling firewall and check. Or will suggest reinstall the OS.
You can also try running antivirus/antispy/CCleaner etc before that.
Regards,
Sails
Mar 11, 2009 | Microsoft Windows Vista Home Basic Edition
'Windows Cannot Connect' Error message
Are you sure your computer is compatible for the wireless, and does it have the necessary drivers?
Apr 02, 2008 | Arris SURFboard SBG900 Wireless Router...
Error code
F6 is a communication error. It is either a loose connection to the control board, or the control board is shot. They should have diagnosed this when they came out to fix it. Open it up, and look for loose connections.
good luck
Feb 16, 2008 | Kenmore 69682 Microwave Oven
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
