Question about Canon Pixma iP6600D InkJet Photo Printer
Paper feed I want to print multiple copies and have chosen the number but it only prints one copy at a time. This is a first. What am I not doing?
  • skyetop Oct 14, 2008
    I had already done that and tried everything else too
    Sergeant:
  • 196 Answers
In the printer dialogue that pops up prior to printing choose the number of copies
Posted on Oct 14, 2008
My zebra tlp 2844 not print multiple copies even if I specify the number of copies in the setting of the printer
Do a hard reset on the printer. Completely remove the printer software/driver and reinstall from a new source (manufacturer website)
Mar 09, 2014 | Zebra TLP 2844 Thermal Label Printer
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have an imagerunner 2800 and it only seems to jam in the tray loading area, just bends the long side of the paper randomly. It changes it's performance just like the weather, sometimes I can get multiple...
A couple of things to consider:
Do not load the following types of paper in the paper drawer. Doing so may cause a paper jam.
- Severely curled or wrinkled paper
- Heavyweight paper
- Transparencies
- Paper on which color images have been copied.
- Paper which has been copied on using a digital full color copier (do not copy on the reverse side
either).
- Paper which has been printed on using a thermal transfer printer (do not copy on the reverse side
either).
Also, what # paper are you using?
Oct 12, 2013 | Canon (6981A002AA) for imagerunner 2200,...
Continuous jam paper feed cl3500n
I THINK THE NUMBERS BUTTON HAD PROBLEM, TRY TO CHANGE THE NUMBERS BOARD & SEE IF THE PATTERN STILL PERSIST. IF THE PATTERN PERSIST ALTHOUGH YOU INSERTED NEW NUMBER BOARD, THEN YOU HAS TO GO IN SP MODE TO CHANGE PRINT SETTING
Sep 26, 2013 | Ricoh Aficio SP-C210SF Printer
How can I make copies?
The 7760 isn't a copier. You can make multiple copies of whatever you're printing, but but it can't make a copy of a paper document.
The paper loading instructions begin on page 8 of the basics guide. If you need the manuals, you may download them from here.
Oct 26, 2012 | HP PhotoSmart 7760 InkJet Printer
When I print a one page document, tray 1 prints on multiple papers at a time. 1 page prints on 5 pages.
If you don't have a manual, you can find one here
My guess is either on the printer or the driver. Skimming the manual, it doesn't seem that you can set the default number of pages printed per sent print job on the printer, but that is something I would look into. This is a nice office printer, perhaps the printer is set to print multiple copies of everything it is sent. You could determine if it is the printer or driver/computer by printing to it from another computer.
If it is the computer, go into the control panel and select the properties for this printer. In there, check if the number of copies is improperly set to 5. This would happen for every print job sent from this system.
Does it print 5 copies of documents sent from different programs (i.e. Web Page, Word, Excel)? Quite possibly, one time you set it to print 5 copies and that application retained that as default. In that application, rather than clicking "print" click "printer setup" and look through the settings to see if it is requesting multiple copies.
I am 95% sure one of these three solutions will solve your problem.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cannot print double sided
On the machine when a 2 sided document is inserted in the document handler, select the 2x2 button on the console. Press the start button and the machine will feed the document in, and do a reverse of the document for the second scan. In the paper feeder, the machine feeds the paper in and reversed the copy back into the machine, flips the copy then feeds the copy back for the second side to be copied.
If you do not have a m20i, the lower model numbers will not do two sided copies.
Aug 14, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Canon Pixma iP6600D InkJet Photo Printer Logo
63 people viewed this question
old marine
old marine
