Question about Cameras
My camcoder does not play becaue I broke pin in a camcoder. Pine came out when I put plug in It does not work. thanks Ish
    Master:
  • 848 Answers
What is the make and model no of your camera ?
you broke the pin in camcorder it cannot be fixed easily ..... sorry to say that you need to spend some amount in it to get it repaired from the authorized dealer ......
Posted on Oct 14, 2008
Hi there why is it that my sat nav only allows me to enter part of address or postcode and blanks out the rest of the input keyboard. There is no setting on my device to allow all functions of the alphabet...
magellan gps is that kind.the blanking out is to prevent errors. let put it this way. 123 west pine lane . for example
type city... then street. as soon as one letter is typed. search is narrowed to a minimum to make it easier to gps to search your destination with much less errors
type p.( for pine)
then. all letters visible. are for all street names that start with p in the city you selected before. .
then p i
a few letters will be displayed.meaning that only names that start with pi will show. like picture picnic pine pin pint pine pines
when you type pine as for address..
it wil show you all streets that matches city and street
123 west pine
123 east pine lane
123 north pine lane
123 south pine rd
123 south pine ave
your selection will be 123 west pine lane.
if you dont want to strugle with that gps. i highly recommend GARMIN GPS devices
Mar 08, 2015 | GPS
Transaxle... How to check and change fluids on 91 Toyota Corolla
Toyota uses Dex III ATF. You can buy from Wal-Mart:
1) Cheaper: Super Tech DEX III ATF $10/gal
2) Better: Valvoline MaxLife DEX/MER ATF $18/gal
Both are compatible, depending on how much you care about your car and how deep your pockets are :)
To check ATF fluid, look for an orange/red color dipstick (similar to the yellow dipstick for engine oil). You need to have the car in running temperature, shift through from Park, N, D, ... then back to D, N, Park (stopping for a few seconds in each gear). Then go to measure your fluid level.
If you haven't check it ever, it might be pale brown, which may look clean to you, but very deceivingly... becaue it should look red-ish / pinkish. When chemicals broken down in ATF, the red-ish color disappears. It may even be brown and smell burnt, that just mean your transmission is not in a very good shape.
If you do change the ATF, it's good to put a bottle of Lucus Oil brand "STOP SLIP / TRANSMISSION FIX" in it during your fluid change. It is a 24oz. bottle cost about $12 @ Wal-Mart or any auto stores. It will extend your transmission's life regardless. I highly recommend that.
Feb 27, 2010 | 2004 Toyota Prius
How do i put video on the computer
There are two types of storage i camcoder. If it is hard disk Just connect your camcoder with USB to computer. In mycomputer you can see the disk of the camcoder as a new drive there.
If storage is DVD you have to burn it inorderd to copy it to computer.
If you are using a memory card you can remove it form the camcoder and using a card reader you can transfer video to computer.
Thanks
Aug 12, 2009 | Samsung SC-D372 Camcorder
Acer travelmate 2480 the pin broke and is in the power plug
Don't try solder it. you will burn up *********** board. put some super glue on a tooth pick and pull out the pin and get a new power plug
Aug 01, 2009 | Acer TravelMate 2480-2968 Notebook
If pins on cd driver is broke will that prevent the cd player from playing
Pins are mainly used to transfer data and control signals from the mother board to the player.
So if the pins are broken then it will be difficult or impossible for the player to play in its usual way.
It would be advisable for you to change the player but try connecting once . The player might work.
Thank you.
Good luck !
Jul 02, 2009 | Dell Computers & Internet
I have filmed on to a tape, and now am trying to download on to my PC and store it there. How please?
hi
most camcoders do have a USB connectivity cable and using this connect the camcoder to the PC
once connected u will need to install the required drivers for the Camcoder to be recognised by the PC (this is a one time process)
then the firmware with the Camcoder will also provide u with some basic recording software u may install that too and then go to the starting of the tape (rewind on camcoder) and play and at that point in time click on the record button on the software installed on the PC
hope this helps
Cheers
Jun 23, 2009 | Video Cameras
Pine code
Use the universal unlock code who came with the phone.
Good luck to you
Nic
Jan 16, 2009 | AT&T Motorola c168i Pay-As-You-Go Cell...
Camcoder (Panasonic PV-GS15) does not play back recording
Sorry to say- but it is trashed.. It would cost more to fix it than it would be to buy a new one.
May 06, 2017 | Panasonic NV-GS10 Mini DV Digital...
Digital Video Camcoder
What you are seeing is digital drop out. This is usually caused by dirty heads. Head cleaner tapes rarely fix this. You shuld have this unit serviced requesting a complete cleaning of the heads.
Dan
Sep 05, 2008 | Canon ZR100 Mini DV Digital Camcorder
Need help
Download Driver
http://esupport.sony.com/US/perl/swu-matrix.pl?upd_id=1452
Install then download and install a video program like movavi videosuite or ulead videostudio (i personally recommend movavi).
Plug in the camcorder and switch it on, put it on play/edit and play the video, press record or capture in the software and let it record!
once the video scene in the camera is done, stop the recording and do what you wish!
GOOD LUCK!
Jul 02, 2008 | Sony Handycam DCR-TRV265E Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
