Question about Sony STR-DE845 Receiver
Sony DAV-HDX500/HDX501W Center Channel
My center channel has never worked since I bought above unit. Have connected it as per mnual instructions. Checked the wires to see if they were connected. They were. Even the cable came out. Connection was right. Any suggestions b4 I call the calvary?
David
    Scholar:
  • 92 Answers
Try connecting it to the left or right output from the amp to make sure the speaker actually works. It might be the receiver that's the problem. Also, you must be in one of the surround sound modes on the receiver and not the "phantom" mode as it does not give output to the center channel.
Posted on Oct 14, 2008
My older Sony Home Theatre/DVD player sometimes will not output any sound.
Sony eSupport - DAV-HDX500 - Support
https://esupport.sony.com/.../model-home.pl?...DAVH...
Sony CorporationHCD-HDX500 - DVD/Receiver Component for Home Theater System ... How to troubleshoot if there is no sound or intermittent sound from the speakers.
[PDF]DVD Home Theatre System - Sony
https://docs.sony.com/release/DAVHDX500.pdf
Sony CorporationDVD Home Theatre. System. Operating Instructions. DAV-HDX500/HDX501W ... not expressly approved in this manual could void your authority to operate this ...
Sony DAV-HDX500 No Sound : hometheater - Reddit
https://www.reddit.com/r/.../3nenei/sony_davhdx500_no_sound/
RedditOct 4, 2015 - My Sony DAV-HDX500 only plays sound when using the built in dvd player. ... Sony system you have does have a digital optical input so that's ...
Jan 10, 2016 | Sony DAV-HDX500 System
Sony STR-DH510 Multi-channel AV receiver connected to cambridge soundworks ensemble IV w/ passive subwoofer: no sound from center channel during viewing, or during speaker level test- all other speakers...
The STR directs sound to the center as instructed by its speaker setup. You say the center does not work on calibration. Is it defined?
Prove another speaker does or does not work on the center output. Then we'll know if it's the receiver or the speaker ensemble that has the problem.
Have you checked the manual for this "
There is no sound, or only a very low-level sound is heard from the center/ surround. "?
Aug 03, 2010 | Yamaha DSP-A1 Receiver
No color when playing DVD's on Sony DAV-HDX500.
What's different? The video connection type, maybe? If you're using Component cables (Red, Green, Blue) you might want to check their integrity.
Jul 01, 2010 | Sony DAV-HDX500 System
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Apr 21, 2009 | Sony DAV-HDX500 System
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
No sound in center rear channel home theater
Must have a 6.1 or 7.1 source for this channel to work.
Does your receiver have a 'test' mode in which it pipes pink noise through each of the speakers... try that to see if it is actually hooked up correctly.
Mar 09, 2009 | Sony DAV-FR9 System
How do i hook up my ipod to my Sony DAV-HDX501W
The DMPORT adapter comes with the surround sound and you just have to plug it in the back of your sound box and youve got it!
Jan 24, 2009 | Sony DAV-HDX500 System
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
Hooking up these speakers with STR-DG810 receiver
ya does need a power sub out from a mini unit big sterios have sub pre outs sends signal only u could use speaker but u may blow them i would buy a kilshpsh set best buy 5.1 299 bucks to tie in sterio rock ya aaway
Jan 16, 2008 | Sony DAV-HDX500 System
No innputs on my ht
I believe that you will need to purchase the accessories from Sony, such as either the Component Input, or HDMI. The accessories plug into the built-in DMP. Your best bet is to consult a Sony Service Center in person, hopefully with your preferred satellite input connection "in-hand".
Jul 29, 2007 | Sony DAV-HDX500 System
Sony STR-DE845 Receiver Logo
128 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
