Question about GE Security Simon 3 Wireless Home Security System
Simon 3 Hi I can not find Option 97
Hi I can not find Option 97 HWIN1 Output Function when I go to option 97 it says invalid Thanks
    Problem Solver:
  • 6 Answers
It was not programed in your systm or you deleted it somehow
Posted on Oct 17, 2008
Simon 3 calls out invalid when pushing done button
You need to contact the company that installed it originally and have them remotely restore the factory code if not you have to default your system to the factory code.
Mar 14, 2013 | GE Security Simon 3 Wireless Home Security...
How do I change the phone number that my GE Simon Security System calls when the alarm is triggered?
Open the front cover, enter the installer code and "add" the new phone number in "Option 4" as the Primary phone number. "Option 5" is the secondary phone number location on the Simon 3.
Aug 21, 2011 | GE Security Simon 3 Wireless Home Security...
Entry delay is set correct but I want it to call out more quickly when the alarm actually goes off. It seems to wait too long. Do the entry delay and the actual alarm call out delay always the same?
Installation manual is here:
http://www.sdilink.com/GE%20Manuals/Simon%203%20Install.pdf
Programming starts on page 17.
Dialer Delay is option 17 on page 29. It's default setting is 30 seconds.
To set Dialer Delay, press:
1.Add
2.Option #
3.17
4.Use the numbered keys to enter the time 005 -
254 seconds (all entries must be 3 digits).
5.DONE
To turn off Dialer Delay, press:
1.Delete
2.Option #
3.17
4.DONE
Hope this helps.
May 10, 2011 | GE Security Simon 3 Wireless Home Security...
SIMON 3 panel acknowledge code?
Check and make sure they did not put a secondary number in Option 5. also I would delete the account# in Option 7.
AlarmProfessor.net
May 05, 2010 | GE Security Simon 3 Wireless Home Security...
GE Simon 3 Alarm: Reseting Dealer and Installer Code!!
Here is the manual. See System Programming on page 11 for default codes.
Dec 21, 2009 | GE Security Simon 3 Wireless Home Security...
Unresponsive door sensor--Simon 3
If it is a newer model there are several setting as to which reed switch you are using or if you are using the wired option. Contact the professor.
AlarmProfessor.net
Sep 04, 2009 | GE Security Simon 3 Wireless Home Security...
Goes off even when disarmed!
This is from page 19 of the Simon3 manual found here:
http://www.safemart.com/manuals/simon3.pdf
It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
select.
5. Press 41. Panel announces, Option 41, press again for next option or done to
select
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
select.
delete
6. Press DONE. Panel announces, Option 41 deleted.
Dec 26, 2008 | GE Security Simon 3 Wireless Home Security...
GE Simon Security System - help!!
The default for option 10 is 30 seconds and option 11 is 60 seconds.
It sounds like option 10 is turned off because when turned off the entry delay is set to 005 seconds. All entries must be 3 digits.
You ca set option 10 and 11 from 005-254 seconds. Hope this helps
Aug 12, 2008 | GE Security Simon 3 Wireless Home Security...
SIMON 3 HOME SECURITY SYSTEM
Option "05" Use Secondary phone number. It works every time for me.
Mar 25, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
110 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
