Question about SanDisk Sansa e250 MP3 Player
Sansa e200 no partition found
How can I fix this?
4 Suggested Answers
SOURCE:
SOURCE: Sandisk e200
Press the middle of the player and the menu button at the same time for like 30 seconds or more and it turns off and try it again
Posted on Oct 15, 2007
  • 3 Answers
SOURCE: MY sansa e200 MP3 player
update the firmware.
Posted on Jan 01, 2008
  • 5 Answers
SOURCE: need instructions for sansa e200
Uhm instructions such as like adding music and deleteing
1.To add music you have to have a Media Player and the Usb cord to connect to it. You must drag songs from the Media Player to the right side of the Media Player and then click Ready to Sync
2.To delete music go to My Computer then find the mp3 then it's common sense from there.
Posted on Dec 31, 2008
I erased some things i didn't think i would need from the mp3 player (photo folder, etc.) and now when it turns on it just says "Load main image failed, switch to recovery mode"
STEP 1: Soft Reset
Simply press and hold the power button for 20 seconds. The soft reset would refresh the player. After doing the soft reset, try to turn on the player once more. If this didn't resolve your issue continue to step 2.
STEP 2: Firmware Update
Firmware controls the functions of your device (how your device operates). In cases where the product does not perform as intended, the update fixes the issue by replacing the current firmware with the latest enhanced version.
Please be reminded that for your player to work properly you need to meet the requirements below.
- Windows XP SP2 or higher
- Windows Media Player 10 or 11
To Download the Sansa Firmware Updater, you may copy and paste this link to the address bar of your web browser:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
To Know More on Using the Sansa Firmware Updater:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=306
If you encounter any issues with the Sansa Firmware Updater, we can try to use the Manual Firmware Update.
There are three versions of the Sansa e200 - Version 1, Version 2, and Rhapsody. This can be found by going over to "Settings" if you found "format" then you have a "v2" or look at the back of your player and check the exact model number under the "CE" logo it should say "model:e200" for Version 1; "model:e200 V2" for Version 2; and "model:e200R" for Rhapsody Version. Make sure that you choose the correct firmware version for your device as updating it using the wrong firmware version may render your device useless.
E200 Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=15209
E200V2 Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=13548
E200R Manual Firmware and Instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200R&thread.id=2280
Dec 25, 2010 | SanDisk Sansa e200 MP3 Player
Where can i find directions on using my sansa e200 ijust got it today and have no instructions on how to use it
I uploaded the manual here at fix ya scroll to bottom of fix ya and you will see Find Manuals click it
Mar 31, 2010 | SanDisk Sansa e200 MP3 Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
No connector port on e200
i found the port connector under the battery case which was attached to a case that the ipod was in
Dec 13, 2008 | SanDisk Sansa e200 MP3 Player
SANSA E200 NOT SHOWING THE MENU SCREEN
Try to format the SANSA E200.
You can do this by simply holding down the Power/Menu button for about 15 seconds. After the reset, any changes you have made to the e200 during its last use will be lost.
PLEASE RESET USING THE RESET PIN PRESENT IN THE SIDE.
AND FORMAT THE PLAYER . if this dosen't work your player is faulty
Nov 21, 2008 | Computers & Internet
Sansa e200 won't unlock
slide the hold button @ the top of your player the other direction. hen turn on. this should solve it.
Feb 12, 2008 | SanDisk Sansa e200 MP3 Player
Mp3
well i dont really know how to fix it.. but what sort of mp3 player do you got if u got one from the sansa e200 series try to uppdate the mp3 but google around some and u find alot useful infomation but DONT format all partitions if u wanna make ur mp3 clear delete all songs (format the music partition on your mp3) and then uppdate it i hopes this helps .. i have almost same problems
Jan 13, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 No USB Menu Option?
e200 or c200? I know that problem was fixed on the e200 with the latest firmware update. Download the sansa updater utility at the sandisk website and see if you can upgrade your firmware.
Jan 06, 2008 | SanDisk Sansa e200 MP3 Player
Sansa E200
You may have uploaded the incorrect or have had unstable power connected to your Sansa E200 when updating. If that is so, your Sansa E200 has been bricked and it's useless. This is the correct Sansa E200 Firmware Updater, "http://www.sandisk.com/Retail/Default.aspx?CatID=1376" (Note: Sandisk is Sansa)
Aug 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
