Question about U-Line Icemaker
Water runs, but no ice being made.
We have a uline clear 2060. Last Friday night it was full of ice, but when, during a party, we used the ice, no new ice was made. I've cleaned the machine; shut it down overnight; and nothing! Any ideas?
  • 958 Answers
Check if the fan near the condenser is still running.
check also the lever if it is in the down position. if it is in the up position, that means you turn off the ice maker.
check if there is frost on the freezer, if it is cooling very well.
keep me posted,
drcool
Posted on Oct 14, 2008
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Have a new frigidaire how long does it take for ice bin to fill after waterline install
Ice maker will call for water 12-14 hours after plug in. If the ref was running and then Waterline was connected it should call for water in 4 hours or less. Easy rule, after 24 hours, ice bin should be full.
Dec 05, 2012 | Refrigerators
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
Our icemaker makes cubes, but leaks water from the ice tray area, creating a 2 inch block of ice in the bottom of the ice cube collection bin each night.
Have a look at the manual on page 6 for adjustment procedure.
Also, your leak may be due to a water valve that is not able to turn off 100%. Valve replacement would be necessary. Unplug your icemaker electrical, and empty the ice. Leave the water turned on. If you keep getting water collecting in the bin, you are likely looking at a water valve replacement (not hard at all, just inconvenient).
Oct 12, 2010 | U-Line ULine BI2115B00 Black Echelon 15"...
Water still runs into ice bin after trays are full on our uline ice maker
This happens when the motor is running slow or the water switch is sticking. To take care of both things you need to replace the faceplate on the icemaker.
Sep 14, 2009 | U-Line Icemaker
Model AM-150BAF ice machine. Water was down at store last night. Now today it isnt making ice. and yes we have water today.
it often takes a full 24 hours for an ice machine to get back up and running and make its first batch of ice.
Aug 14, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
Drain pan underneath fridge is filling on a daily basis
The system is designed to evaporate that water using the warmth of the compressor.. is your compressor warm ? (the drip tray sits on top of it) I see that model has an Ic e maker... to check that the ice maker refill is not running on too long, switch off the ice maker, by lifting the wire arm that checks the level of the ice in the storage bucket.. leave it turned off for a day or two.. empty the drain pan, and check it again after 24 hours.. but if the ice is already full, the water problem may APPEAR to be resolved already, but will return when the level drops and the ice production begins again.
If it is just condensate, then the drain pan should be able to contain the amount it produces, but 3-days straight, would indicate to me, that is not that... if your water pressure is good, it may be that the ice tray filler solenoid is being held open a fraction too long (maybe a second or so) and as the fridge is new, it will be making lots of ice to fill the container up,... so lots of small overfills.. mounting up to a full drain pan. Under normal use,.. other than parties and festive nights, when you use a lot, the water should evaporate faster than it is produced, but it shouldn't be happening at all.. if it is that, then turn the tap at the back of the fridge to where the cold water dispenser slows down slightly.. that should be enough to prevent it continuing.. IF that's the problem.
Apr 24, 2017 | Frigidaire FSC23F7D Side by Side...
Ice Maker in door of freezer-ref combo.
The ice maker has a float or full detection device that shuts the water off when trays are full. If you are sure this is where the water is coming from, then that's it.
Dec 27, 2007 | Freezers
U-Line Icemaker Logo
194 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
