Power button I have an LG 36,000 btu unit. While cleaning the filters something odd happened. The temperature display is reading 4 and nothing seems to be working. The unit is on, but the remote is not changing anything. The remote display changes, but the unit doesn't respond. Also, I tried to switch it off manually, but the on/off button is not working either. It's like it's frozen. And the room temperature is going up. Help.
  • lisahowell Oct 14, 2008
    Worked like a charm. Dr. Cool is the man! Thanks. The display has gone back to normal, and the unit seems to be responding normally. If I have any other problems, I will check with you before calling a technician. I'm especially happy because I only get one day off each week and this is it. It was looking like I was going to have to spend it waiting for a service guy, so you saved the day in more than one way. Thank you so much.
  • 958 Answers
Try to un hook the power by turning the breaker off for 30 minutes to reset the electronics. see if it would work after that.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
  • francis rivero Oct 14, 2008
    you are very much welcome lisahowell, this what we do here.
    tnx for the rating and thank you for using fixya,
    drcool
Is this unidentified aircon a 3 or 4 Ton?
Look for nameplate that indicates the BTU's British Thermal Units. 12,000 BTU's are equivalent to 1 Ton. Therefore 48,000BTU = 4 Tons 36,000 BTU's = 3 Ton
Feb 14, 2016 | Heating & Cooling
Why does it beep when plugged in?
as there are two control boards in ac units ( split systems) and one in a window unit
it could be the inside board ( they do not suffer power surges to well or vermin infestations at all )
before you waste more money I suggest that you get a technician in to determine the fault and if parts are readily available.
Jun 24, 2015 | LG LW1012ER 10,000 BTU Medium Window Air...
What does the E1 mean on the display
I read that this is a filter problem. There may be more than one. Turn it off and clean the filter. For many window air conditioners this code is simply a reminder to clean the air filter. After like 750 hours of run time this code pops up and you have to clean the filter and then reset the unit before it will work again. To reset the code you need to simply unplug the unit and then plug it back in again. On other units you need to hold down the power button while you reenergize the air conditioner.
On another make of window air conditioner you need to push the "fan" button twice and then the "mode" button once to reset this code. Still another person found that the circuit boards where going bad and they had to replace them to get the unit to work.
Jun 08, 2014 | Amana ACD105E 10000 BTU ENERGY STAR ROOM...
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
My LG portable AC Model #LP1111WXR wouldn't turn off had to unplug it. Now won't turn on.
Unplugging the unit lets the tiny computer like microprocessor reset--means problem is in the brain of the unit or its power circuit.
Jun 14, 2012 | LG 11,000 BTU PortabAir Conditioner -...
Pentair MasterTemp 400 Stack Flu Sensor Reading Stuck
check gas pressure and for clogged burn tubes unit is overheating
May 12, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
Nothing works, displays numbers 1 thru 4.
What you're describing sounds like a corrupted controller, or maybe there is some grease, etc. on the controller, maybe where the keypad plugs into the controller.
Can you post a video demonstrating what happens?
This sounds really odd!
Jul 19, 2008 | LG LMV1630ST Microwave Oven
Zanussi ZWF1437W Washing Machine Problem
My Zanussi is 5 years old it onn th whole works well not making over the odd noise but is often marking my clothes with splashes of light brown after washing, which dosn't come off even with stain remover .
What could this problem be.
RR
Dec 11, 2007 | Zanussi Washing Machines
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
