Question about Mico DVDR310 DVD Recorder
Volume uncontrollable on my Mico Alma t300 when playing 5.1 DVDs
When Prologic and surroundsound 5.1 is ennabled Volume control is disabled and Very loud
I can also not select which Speakers play ie i would like sound sterio sound from all speakers even in tunner mode
Have a load uncontrollable volume with my Pioneer VSX-d409 receiver. A suggestion for a low volume problem was to correct with tuner cleaner (potentiometer ) problem. Can this be corrected by me as perhaps...
Your problem is not with FixYa, but rather the volume control potentiometer on your Pioneer receiver. As for whether you can fix it yourself, that depends upon your ability to disassemble the receiver to gain access to the volume control and make the repair
Jan 16, 2013 | Pioneer VSX-D409
I have a coby CSP96 speaker system. it said on the manual online that i found on the cobyusa.com site that there should be a volume control on top of the sub-woofer but there isn't one there. i can only...
I am having the same problem. I also have the combo dvd and theater system. I also read that the sub woofer is supposed to have a volume control on it but its not there. The only way to control volume is to connect to coby dvd player. This dvd player is beyond terrible. DVD looks bad and sound is miserable. I hooked up xbox 360 to my samsung 52 inch, then on the outputs of my tv into the inputs of the "TV" section on the Coby Sub woofer. At this point great sound quality comes from the xbox and all speakers, but the volume is uncontrollable and is blasting loud. Tv volume control does not work either. I am stuck like chuck and have not found a solution. This has to be one of the worse purchased i have ever made because i am forced to use a terrible DVD player just to get some sound through the speakers. I dont understand why on the speaker systems you buy without dvd combo has a volume control on subwoofer, but on the combo subwoofer doesnt have it. Just terrible. I will continue to look online and try and find a solution other than smash it to bits.
Oct 19, 2010 | Coby CSP-94 Speaker
I have the Bose 321 GS II, when watching a dvd we get the surroundsound, when we watch tv the sound is only from tv - help
You have to run an audio path with RCA cables from the TV (or the cable box, as applicable) to the Bose, then disable or turn down the TV volume.
Nov 28, 2009 | Bose (321GS) System
Volume is not working
get a splitter that allows you to plug 2 sets of headphones in the portable dvd player.
The sound is the only place were this machine falls short. The sound is okay at best with the built in speakers, but any background noise makes it nearly impossible to hear anything from them even with the volume all the way up. Not surprising since due to the size of the player the speakers are only a little bigger then headphone speakers, but with headphones or portable plug-in speakers the sound is superb. Besides the sound the only 2 complaints are that you can not control the volume with the remote and that the power switch is too easily turned on by accident (do not travel with the battery attached or you will find you have no charge when it comes time to watch a movie). The battery lasts 3.5 to 4 hours, long enough for 2 short movies or 1 long one.
also checkout The volume button is on the right side of the uint.
, headphones are a must, or get a device to play the audio through your car stereo ($15-$25). The player has the option to either input or output the A/V so you could play video games on the run or you could hook up a VCR and watch VHS...be creative
Apr 01, 2009 | Shinco SDP-1850 Portable DVD Player
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sound problem on new Aspire
You can check already the audio setting in your dvd software maybe the volume is low or mute. Click Start, accessories,entertainment and volume control adjust the volume to higher or look if the volume is mute
Apr 14, 2008 | Acer Aspire 3680 Laptop
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
UNCONTROLLABLE SURROUND VOLUME
bad solder connections and or dirty controls.
Dec 12, 2006 | Technics SA-AX530 Receiver
Mico DVDR310 DVD Recorder Logo
67 people viewed this question
Top Mico Televison & Video Experts
Are you a Mico Televison and Video Expert? Answer questions, earn points and help others
