Question about Toshiba e-STUDIO 50F Plain Paper Laser Fax
Replacing Start Button on Fax Machine
The company I work for has a Panafax UF-560 and we need to replace the start button on the machine. We do not exactly know how to take it apart to do so without breaking it. It should be fairly easy with a little guidance that is why I am trying to find something on the web before we pay a technician.
Any help at all would be greatly appreciated.
Thanks
    Genius:
  • 2,120 Answers
Open the doc feeder
Use a screwdriver to pry black base away from keyboard
Unplug keyboard large white connector.
Remove 17 gold screws
Carefully disconnect ribbon cable by pulling white part of ribbon plug away.
Unsolder one of the switches you never use (contrast?) 2 pins.
Unsolder start switch and replace
Reverse disassembly.
Posted on Oct 14, 2008
How do I replace the pf kit on a brother mfc-9325cw. I have the replacement parts.
Laura, you get the necessary tools, get access and remove the old parts and replace with new ones. Make sense?
Jan 10, 2017 | Brother International Brother MFC-9325CW...
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
My 202 doorbell does not "react" if the button is pushed AFTER my neighbor unlocks his car by using his remote key. Can I change the frequency range of the doorbell?
look for a cover that has small switches under it. You can change frequencies there. You must match the door button the same way .
Nov 19, 2014 | Office Equipment & Supplies
We have forgotten the Administration password for our EStudio 350 & 450. Is there any way of resetting? Thanks Ben
The default password is either 12345 or 123456.
If neither of those work then, turn machine off then power on while pressing the 0 & 8 keys then enter 263, then press Start. It will then display the Admin Password.
Mar 17, 2014 | Toshiba Estudio 200L Copier
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
Forgot password toshiba estudio 450
Oct 23, 2009 | Toshiba Estudio 200L Copier
restart machine ,then press the 0 & 8 keys,enter 263, then press Start. You should see admin password on the screen.
May 05, 2009 | Toshiba Estudio 200L Copier
Toshiba e-STUDIO 50F Plain Paper Laser Fax Logo
Top Toshiba Office Equipment & Supplies Experts
CheckitRight
CheckitRight
pkwc
Electro Med Services...
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
