Question about Kenmore 15208 Mechanical Sewing Machine
Thread is bunching up around the bobbin casing
Once I start to sew, the thread starts to get caught up around the outside of the bobbin casing. I have a Kenmore model # 385.123 and no manual.
Any help would be greatly appreciated.
Thanks.
Need a owners manual por sewing machine 15208 thanks
Posted on Sep 07, 2010
    Problem Solver:
  • 17 Answers
On the bobbin case is a small screw if it is to loose the thread won't feed like it should make sure that screw is tight but not so tight you can't get the thread through it. Also check to make sure you have threaded the top right. hope that helps
Posted on Oct 14, 2008
techworm
  • 56 Answers
SOURCE: thread getting caught around bobbin case
It isout of time you need to time it.by adjusting the screw on the bobbin holder turn it left or right and the tension knobe and foot tension.
Posted on Nov 12, 2007
SOURCE: Thread bunching and knotting under fabric
After talking to my favorite Bernina dealer... I discovered a fix for my machine. And I"m going to guess it will also be your problem. The hook has grooves worn into it. This either needs to be filed very hard to remove all of the grooves or you can purchase a replacement hook. By the way they only make metal replacement hooks and my machine has a plastic one. So this must have been a common problem. My husband just filed mine down considerably and it's finally working. I am still planning to buy a metal hook to have on hand. Hope it helps you! Lydia Jo
Posted on Feb 25, 2008
SOURCE: Bobbin thread bunching
I have the same problem too and I have a singer. I have done everything. Is my machine just kaput?
Posted on Oct 02, 2008
  • 76 Answers
SOURCE: Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Posted on Sep 03, 2009
  • 152 Answers
SOURCE: bobbin thread gets bunched up and loud clicking sound
The problem is never the bobbin when you have this problem. It's the top thread. Take the thread off the top of the machine and rethread the top. Make sure the small tension dial is on 4 or 5 (the larger dial on the front left is for the pressure on the foot, not the thread tension.) After you thread the machine, put the pressure foot down but NOT on the thread. Then pull gently toward the back of the machine. When you do, the needle should bend slightly backwards before the thread comes through the machine. If it pulls with no resistance you could simply have "fluff" or remants of thread between your tension discs. If you do, put the dial on zero and using an old needle, clean between the discs and try threading the machine again with the "pull test" I described earlier.
No tension on the top of the machine, lets the bobbin tension win and it pulls all the thread to the bottom of the fabric.
Posted on Oct 06, 2009
Embroidering in blue thread, and the white bobbin thread was coming through on the material. Adjusted the tension to -8, sprayed the bobbin casing and area lightly with WD40, changed the bobbin, changed...
The white bobbin thread was showing on the top of the material correct? Make sure bobbin thread is in the tension correctly, check the top thread spool and make sure thread is not caught around it, if you have a manual top tension make sure that is set correctly. Personally I would never use wd40 in a sewing machine, sewing machine specific oil is always better. You seem to be describing two different problems. The thread bunching is probably from the thread jump out of the take up lever.
Sep 12, 2013 | Brother Sewing Machines
I am sewing scout badges on a uniform and when I sew there is a bunch of needle thread bunched up on the bottom (the top looks fine). And the needle thread gets all caught up around the bobbin.
Clean out the bobbin area if there are any thread tangles there.
Refer to the maintenance section of the manual - see the configuration of the bobbin case and shuttle race? The bobbin case as an extending arm and the race a notch. When inserting the bobbin case into the shuttle, turn the handwheel so the needle is at it's highest position. Then lift the lever on the back of the bobbin case and insert the cast into the shuttle, arm pointing straight up toward the bed of the sewing machine.
Now thread the machine with the presser foot up - always - and see if the tangling stops.
When you forget to lift the presser foot before threading the machine, the tension control does not open to capture the thread. Then when you begin to sew, the top thread has no tension, and the bobbin thread, which does have tension, pulls the top thread to the bottom in messy loops.
Jun 25, 2011 | Kenmore Sewing Machines
When i start to sew, my thread gets caught up on bobbin. the string gets wrapped around the bobbin then breaks the thread. it seems as though the bobbin is sitting a hair too high. ? ? ?
Make sure there is no fluff/lint within the bobbin case causing the bobbin to stand proud. Pressure from the bobbin thread can sometimes stretch the bobbin itself.. replace the bobbin with a brand new one. Double check your threading be removing all thread and starting from scratch.
Dec 12, 2010 | Singer 57815 Mechanical Sewing Machine
Bottom thread bunching
Oil behinde the bobbin holder so that bobbin holder can run smooth in the bobbin casing. wcbotha@yahoo.com
May 11, 2010 | New Home HF-2022
Hi, my thread gets caught and pulls the materal into the foot and i can not sew due to the jamming and the thread get all bunched up by the bobbin
I had similar problems when I first started sewing. Try adjusting the tension in your thread - less tension for lighter fabrics, more tension for heavier fabrics. This will stop the needle from pulling the threads in the fabric.
As for the thread getting bunched up in the bobbin - this is most likely because your bobbin is the wrong size for the machine, or that you did not thread the bobbin properly. Try re-threading, this time making sure you pull the thread into the bobbin container tightly. This should stop the bobbin from jumping around the container and spitting thread.
Feb 27, 2010 | Brother Sewing Machines
I am having trouble with my bobbin . When I put into the sewing machine and begin to sew the cotton just bunches up and jams . Any suggestions
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
Hope this helps.
Sep 13, 2009 | Husqvarna Designer I
hope this helps
Sep 03, 2009 | Kenmore 15208 Mechanical Sewing Machine
Thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Feb 26, 2008 | Brother LS-1217 Mechanical Sewing Machine
Tangled bobbin thread
Okay. I had this problem too. try taking the bobbin casing out. I had a bit of thread lintg caught in a remote area of the under-plate area. Blow it out with canned air and oil your machine. That should help. It fixed mine.
Jan 16, 2007 | Singer CE-200 Quantum Futura Computerized...
Kenmore 15208 Mechanical Sewing Machine Logo
287 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
