Question about Electronics - Others
I can not open my Flash Drive
I Can not open my 2GB ABMS Flash Drive.When i try to open it says that i have to format it but i can not do that as it contains valuble data.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 147 Answers
Your flash drive might have caught virus or viruses that corrupted your files, thus, needed to reformat and can't be open...else, u can't use your flash drive anymore and may cause total lost of data in the near future....the only choice t continue using your drive is to reformatting it. But the consequence of it is the data that you are having right now will be deleted. Be careful for viruses next time...thank u!
Posted on Oct 15, 2008
Sudenly kingstone usb changed to skymedi and doesnt formated
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
My flash drive is 2gb. the flash drive is empty and has nothing on it but it says that there is only 15 MB available.
First thing I would try is a quick format. Go to My Computer, right click the drive, choose Format.
Nov 12, 2010 | Computers & Internet
How can i fix my kingston dt101 2gb flash drive
The OS format tool will not format flash driveswhat you need is this one
http://en.kioskea.net/download/start/download-127-hp-usb-disk-storage-format-tool
Although it was produced by HP it works on any,
Jul 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My flash disk does not format what is the problem? i put the flash in the windows xp system port it becomes recognised by the system i try to open it ,it tells me the disk is not formated do you want to...
Your flash disk has been infected by virus that is why you are unable to open the flash drive. The best thing you can do is to download a good antivirus such as MacaFee or Avira or scan the flash drive for virus.
An alternative thing you can do is to insert your flash drive into a linux operated pc such as Fedora, Ubuntu, Open Susie or Redhat and then delete all the files in the Flash drive and format it
Apr 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer Micro 2GB Usb Flash Drive. Windows was unable to complete format!
Try this:
STEP 1 - Optimize the flash drive for performance
1. Plug in the device to the PC.
2. Double-click My Computer.
3. Right-click on the flash drive, then select Properties.
4. Click the Hardware tab.
5. Select the SanDisk Cruzer USB Device disk drive, then click Properties.
6. Click the Policies tab.
7. Select Optimize for performance, then click OK.
STEP 2 - Format the flash drive
1. Double-click My Computer.
2. Right-click on the flash drive, then select Format.
3. In the File system list, click NTFS.
4. Click Start.
5. Click OK to start formatting.
Jan 13, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Drive wil not allow coping with 1.8 GB open
Not sure why it won't copy anything to the drive, but you can try formatting it and then copying to it once the format is finished.
Plug the device in, then open "My Computer" and right click on the drive letter that is assigned to the flash drive, then click "format" and leave all the options alone.
A quick format should be all that's necessary. If this doesn't work, I'll have to let another Expert take over.
Dec 31, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
A-data usb flash drive(no disk)
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jun 29, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My flash drive says I am using data when I am not
i mean when i insert my flash disk in to the computer and then try to open it displays format disk
May 01, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Sandisk micro sd 2gb problem
2. Format
Nov 10, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro USB Flash Drive Hard Drive
i cant open the flash 2gb... it cant format also ... due to some errors so tell me how to format!!!
Mar 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Electronics - Others Logo
88 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
