Question about Minolta Office Equipment & Supplies
On a Minolta BizHub 451, the counter must not be working right. It hasa claimed I used 31,000 - copies when I only have gone through about 12,000 pieces of paper (not double sided. Any thoughts?
  • phyatt Oct 15, 2008
    95% of my copies are 8.5 x 11.
It is a new lease; new machine.
We scan to e-mail, but not much.
Thanks
Posted on Oct 15, 2008
It is a new lease. We do scan to e-0mails, but not much.
I appreciate your thoughts help this.
    Genius:
  • 2,120 Answers
Anything longer than 11" counts as 2 copies?
Posted on Oct 14, 2008
  • Leroy Elliott
    Leroy Elliott Oct 15, 2008
    Was it used when you got it, or is a lease?
    Some copiers count scans to PC also.
How can I solve colour registration error in konica minolta Bizhub c 451 printer. Thank you, Uchenna.
run registration procedure in service mode. any p codes check the black image unit as is the reference for color registration
Mar 18, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
C 2557 error Konica Minolta c 451
this problem at/dc you should replace developer
Sep 17, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
Error code c-fe03 in konica minolta BIZHUB C-451 ?
MFP board issue might have a tech re flash the firmware
May 12, 2015 | Konica Minolta Bizhub C451...
Customer has C451 bizhub that has unresponsive control panel except it will make ONE copy after hard reboot. Then no buttons work, particularly the Utility/Counter button. Can't get in to service mo
Hi
The bizhub C451 is a Konica-Minolta machine and I have found a webpage here:
Error Codes Konica Minolta bizhub C451
that details the error codes that can occur on your machine. I know that this may not be of much use as you don't appear to have any error codes appearing. However, there is also a link at the top of the page from which you can get a copy of the Service Manual which will probably have a lot more detail in it and may answer your question.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 28, 2014 | Office Equipment & Supplies
Konica Minolta bizhub 164 m2
press the Utility button,
then Stop 0 0 Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Which are very important for copy quality, and not replacing them may cause more harm than good.
Jul 11, 2014 | Minolta bizhub 180 Black and White Copier
Minolta bizhub 164 code m2
May 13, 2014 | Minolta bizhub 200 All-In-One Printer
Error code c 2151 on konica minolta c 451
Open the right side, see the sponge roller on the door check to ensure it is properly installed. DO NOT CLEAN with any liquid!!!!! Replace or have a tech come and review the issue
May 05, 2014 | Konica Minolta bizhub C450P Laser Printer
Reset error m1 in minolta bizhub 1811
Utility button, then stop 00 stop01 then use arrows to get to 9. Clear data, then clear maintenance counter =M-1
Nov 10, 2012 | Minolta Bizhub Di1811p Copier
Minolta Bizhub di3510
Because after so many copies it needs to be replaced along with cleaning blade and the developer.
try web site below as place to start to get them or have a konicaminolta tech come out do it right, such as clear the counters, install the parts, run the required F8.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 24, 2012 | Minolta Di3510f Bizhub Copier
Bizhub C250, Total Counter Working but not B&W or Colour Counter
Unfortunately you cannot reset those electronic counters.
I'd suggest reloading the firmware to try and solve the issue going forward.
Feb 04, 2009 | Konica Minolta bizhub C250 All-In-One...
90 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
