Question about Amana AKS3040BSSCooktop
Igniter clicks continually until each dial is turned to high heat
the only way the clicking stops is if the dial is turned full on. this is true of all four burners. makes it hard to cook anything that you don't boil!! help!!
michael in cambridge, massachusetts
  • 76 Answers
You may have a bad spark module or a bad potentiometers
Posted on Jan 08, 2009
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
Oct 20, 2013 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Ingiter will either fail to start burner or won't quit clicking on the 1% of the times it does start up the burner
Hi look for adjustments to the lighter and also there should be a sensor tat sees the fire , this sesor allows the main gas to turn on, but only if it feels the heat , kind of like a thermocouple , if you think about about any type problem like this: what is it not doing ? then think what could cause this >/? if you go about any repair this way there is nothing you can't fix unless you need a part !
Dec 05, 2011 | Jenn-Air JGC8430 Gas Cooktop
Igniter wo'nt stop ticking
You need to turn the nob away from the "LITE" setting. Gas cooktops don't have thermocouples, so they just keep clicking until you move the dial off of that setting.
May 08, 2011 | KitchenAid Cooktops
My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Oct 10, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Clicking sound from GE gas stove igniters
u most likely have a gas supply valve problem, the clicking will continue until that is fixed.
Jul 22, 2009 | GE Profile JGP636 Gas Cooktop
Igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
Apr 15, 2008 | Cooktops
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Aug 18, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Amana AKS3040BSSCooktop Logo
102 people viewed this question
Top Amana Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
