Washer will not rinse properly, clothes still to wet for dryer.it's a kenmore
  • 958 Answers
Could be the belt is slipping that is why the drum turns slow. check the belt if it is loose.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
My machine doesn't rinse and drain properly, sometimes the clothes are sopping wet
Maybe you just need to change the motor brushes. YouTube has some great videos. Spares here on Fixya. Did you check out your filter?
Click if helped.
Mar 12, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Have a kenmore washer and I have to run everything thru 2 spins cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn clutch.
Oct 25, 2011 | Kenmore 22422 Top Load Washer
After spin cycle is complete, clothes in washer are still too wet
Check for obstructions in the pump and discharge hose. Check the motor coupler. Here is a video that should help.
http://appliancehelponline.com/topdirectdrivevideo.html
Jun 04, 2010 | Kenmore 22422 Top Load Washer
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
Kenmore 110.27831600 washer fills for about 1 min then quits
thats normal it needs to fill the machine to rinse the cloths
Oct 05, 2009 | Kenmore 63942 Dryer
The washer finishes the rinse and drains but then won't spin the rest of the water out of the clothes, they are dripping wet when I go to put them in the dryer.
your lid switch is bad i can simply prove that to you if you would like ... visit whirlpoolpartssurplus.com call and i can get one sent to you first thing tomarrow
Jun 28, 2009 | Kenmore 24902 Top Load Washer
Clothes way too wet after washing
your washer is not hitting high speed spin thats why the cloths are still wet,bad transmission,sorry-mike
Jun 03, 2009 | Kenmore Washing Machines
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine doesn't rinse
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. Check as well that pump spins and clean from any clogged. Good luck!
Oct 08, 2006 | Kenmore 43042 Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
