Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Sounds like rocks in machine on final spin
There is a really loud sound like rocks spinning in the machine. It is definitely there during final/fast spin - not sure about other spins.
  • Thmolon Oct 15, 2008
    Thanks for the answer, but my machine is just a year old - surely it can't be that dire?!
  • 1,543 Answers
The rear drum seal has leaked water into the rear bearing. Sorry, but the repair is expensive and difficult. It's time for a new washer. Look into the LG models, which are direct drive. Please don't bother rating this, as anything other than a FixYa drops my rating, and I know you don't want to kill the messenger, right?
Posted on Oct 14, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Oct 15, 2008
    On a machine that new I would not expect a rear bearing failure. More likely cause in your case would be an object between the inner and outer drum. I've seen small pocket knives and cartridge fuses, you might see a part from a pen or coins, whatever may have been in pockets. If you are lucky you might be able to get it out without tearing machine completely apart. Some machines have an internal heater which can be removed to access the inner drum area, or you may be able to get at it the same way it got in. (at the front, near the door seal)
    Look through the holes in the inner wash tub and around that front seal area at the bottom.
Spin cycles spins really fast ants sounds like a grinding sound during this cycle.
broken spider arm link, u have 3 on ur drum one breaks it will spin uneven, very expensive to fix, happened to me was cheaper to buy new machine
Dec 30, 2015 | Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
It wont do final spin..makes a clicking noise as it turns the drum during spin
I moved my washining machine in order to check pipes....thought id do a final test spin hoping that it would work changed the temperature setting to higher degress (60) put in on a empty wash for about 5 mins then turned it to fast spin an it slowly started spinning until it finished a complete spin!!!!...dont forget to turn the temperature down again!!!
Aug 23, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Loud noise on fast spin cycle
check the support rods holding the basket maybe one has been dislodged and givng you and unbalanced effect
Jan 09, 2009 | Frigidaire Washing Machines
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag front loader shakes really loud
make sure the transport tie downs have been removed during installation and that all four feet are adjusted properly so machine does not rock.Also make sure your floor is reasonably solid.
Sep 25, 2008 | Maytag MAH21PD Front Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
163 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
