Hi I have a Sony Vaio VGN-S1HP (model PCG-6C1M). It is too slow and running out of hard drive space. I would like to know if I can upgrade the processing power and also increase the hard drive from 40g to say 60 or 80g?
  • ingrid_hay Oct 14, 2008
    Thanks for feedback. However what I am really asking is whether the model I have will actually allow for this type of upgrade. IE is there anough space in there to put all this new stuff in and will it be compatable and will it work?
  • 45 Answers
Well I would recommend upgrading your RAM to 2 GB (Your standard model comes with 1/4 of that) and a 250 GB drive. The RAM would cost you about $80 in parts and perhaps $30 labour and the hard drive should be about $60 in parts and $20 labour. I don't recommend upgrading processors as it can cause warranty problems down the road.
Posted on Oct 14, 2008
  • Arthur Keech Oct 15, 2008
    No problem, it uses industry standard connectors so everything is expandable for sure. If you want to know a little more technical detail with which to upgrade your system, you want to buy a SATA hard drive and DDR2 866 MHz SDRAM for your memory. These are the standard component types you already have installed.
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
HAVE TRIED CHANGE THE CMOS BATTEWHAT CAN I DO NXTRY TO REMOVE BIOS PASSWORD BUT IT COUDNT WORK,?
Sony Vaio PCG and some Vaio VGN Series use the last 7 digits of the laptop serial number to calculate the bios master password. The serial number for a Sony Vaio is often located on the bottom of the laptop on a white sticker. The serial number may also be found by removing the battery and checking in the battery compartment. The link to unlockbiosrecovery.com below works on the following models:
PCG-C, PCG-F, PCG-GR, PCG-GRS, PCG-GRT, PCG-GRV, PCG-GRX, PCG-GRZ, PCG-N, PCG-NV205, PCG-QR, PCG-R, PCG-SR, PCG-SRX, PCG-TR, PCG-V, PCG-VX, PCG-X, PCG-Z, VGN-B, VGN-FS, VGN-S, VGN-T, VGN-TX1, VGN-X
I use http://www.unlockbiosrecovery.com/Unlock_Sony_Bios.php
For $20 they use the last 7 digits of the laptop serial number to calculate the bios master password and then email it to you in an hour. They guarantee it to work and you can call them if you have a question.
Sep 10, 2011 | Sony VAIO VGN-FS640W Notebook
My vga card for sony vgn-t2xp model pcg-4d1m
The model of your sony vaio is VGN-T2XP/L and chassis type is PCG-4D1M
I can only give you a link where you can download necessary drivers, updates/firmwares or original drivers that comes with this unit. It depends on what operating system you are currently using.
If you then upgrade your operating system for example from windows vista to windows 7, then suddenly some hardware including sounds, lancard, vga experienced some troubles, I do suggest you downgrade again your operating system or find appropriate compatible drivers that will work for your new operating system.
In this link you will find something that might help you.
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-T2XP_L
Let me know.
Feb 03, 2011 | Sony VAIO PCG-4D1M LAPTOP LCD SCREEN 10.6"...
Sony Vaio PCG-K23 video files are slow. Any help?
How much RAM do you have? Upgrading your RAM is a good way to improve system performance.
May 29, 2010 | Sony VAIO PCG-K23 Notebook
The screen on my Sony Vaio VGN A250 model PCG 8R7L is showing enterference is there a service manual from Sony for the Sony Vaio VGN A250 model PCG 8R7L I can obtain?
Hi kyle662919.
You may download the Service Manual from the below link:
http://home.comcast.net/~nw_systems/vgnA.pdf
Please open the above link to download the Service Manual for the VGN-A200 Series Notebooks.
Hope this helps.
Please feel free to contact for further assistance.
Jan 22, 2010 | Sony VAIO A250 Notebook
Hi . is vgn sz430n the same as PCG 6Q1L ?? I
Yes, VGN-SZ430N is similar to the PCG-6Q1L.
The only difference between the two coding is that the first one is the model # of the Computer used by the technical support team or sales support team for providing assistance however, the later is the Hardware configuration code of the Computer that categorizes a few models.
Oct 01, 2009 | Sony VAIO VGN-SZ430N/B Notebook
My sony vaio model pcg-7y1l is not working. When
i had the same prob this morning there are 3 things you can try
1 memery
2 proccessor
3 hard drive
if not any of them
try the dvd drive
if not that then try exsternal monitor if dont show on that then motherboard is gone
Aug 14, 2009 | Sony VAIO VGN-AR230G Notebook
Ethernet drivers for sony vgn-fs115m
Hey MIDO Try This Tool
VAIO Launcher 1.4.11 Update Program
This program will update VAIO Launcher pre-installed on the VAIO model listed below.
VGN-S4HP/B
VGN-S4HRP/B
VGN-S4M/S
VGN-S4XRP/B
VGN-S4Z/S
VGC-V3S
VGC-V3M
VGN-FS285H
VGN-A497XP
VGN-A417M
VGN-A417S
VGN-FS295XP
VGN-FS215Z
VGN-FS215M
VGN-FS295VP
VGN-FS215B
VGN-FS215E
VGN-FS215SR
VGN-FS215MR
VGN-FS285M
VGN-FS285B
VGN-FS285E
VGN-FS215S
VGN-B3XP
VGN-B3VP
VGN-S4XP/B
VGN-S4VP/B
PCG-K415S
PCG-K415B
VGN-FS195XP
VGN-FS195VP
VGN-FS115S
VGN-FS115Z
VGN-FS115M
VGN-FS115E
VGN-FS115B
VGN-FS115ZR
VGN-FS115M -- ( Thats Ur MODEL)
VGN-A397XP
VGN-A317S
VGN-A317M
VGN-S3XP
VGN-T2XP/L
VGN-T2XP/S
VGN-T2XRP/S
VGN-S3VP
VGN-S3HP
VGC-RA304
VGC-RA204
PCV-RS704
PCV-RS702
VGC-M1
VGC-V2S
VGC-V2M
VGN-T1XP/L
VGN-T1XP/T
VGN-B1XP
VGN-B1VP
VGN-S2XP
VGN-S2VP
VGN-S2HP
VGN-S2XRP
VGN-S2HRP
VGN-A297XP
VGN-A295HP
VGN-A217S
VGN-A217M
VGN-A215M
VGN-A215Z
PCG-K315Z
PCG-K315S
PCG-K315B
PCG-K315M
This update resolves the problem of registered applications not launching from the VAIO Launcher toolbar.
Note: This program requires VAIO Zone 1.2.05 or later. If your VAIO model comes with VAIO Zone 1.2.02, you must first update VAIO Zone before running this program.
Download and installation
1. Download the file SOAVZN-01028300-UN.exe and save it to a download directory
2. Close all running applications
3. Go to the download directory and double-click SOAVZN-01028300-UN.exe
4. The InstallShield wizard starts
5. Click Next and wait while setup is installing the new software
6. Click Finish when the installation is complete
HERE
Apr 15, 2008 | Sony VAIO FR130 Notebook
Computers & Internet Logo
295 people viewed this question
David Payne
David Payne
