Question about Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range
Smeg A2-2 no electricity...
My Smeg A2-2 has died totally. It did not trip the 32amp CB in the fuse box but there is no electrical activity, ie no display no ignition no lights! Typically the warranty has just ran out by weeks, any suggestions welcome
  • 14wishy Oct 15, 2008
    There is no sign of burn out and I have changed the internal fuse at the socket, no joy. £70 callout for Smeg engineers is a bit steep. I will invest in multimeter first!
Thanks Tresilla will have a look, am I looking for burn out here too?
Posted on Oct 15, 2008
    President:
  • 1,462 Answers
Check first that you have power to the appliance - open the cover over the connection box and check with a multimeter. also carefully check that the connection box is not burnt out. this is likely not a fault with the cooker but your power input
Posted on Oct 14, 2008
  • douglas smith Oct 15, 2008
    i also have a recollection of a plug and socket for the wiring loom located behind the back panel on the rhs looking from the rear. worth having a look
Top element not warming but does work when grill is activated
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer?
http://how-2-repair.com/buy-paul-a-beer/ Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 11, 2014 | Smeg Ovens
Fuse board switch off
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 01, 2014 | Smeg SE399X/5 Stainless Steel Electric...
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
Sep 20, 2013 | Smeg Ovens
Smeg gb-ie
Jul 12, 2013 | Smeg Ovens
Blows mains fuse
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
My smeg electric oven model no. SA22XMF/7 is not heating after we lost power. Fan and light is working but the heat is not. What can that be ? Is it the fuse or the element has gone
Nov 29, 2011 | Smeg Ovens
Smeg electric oven model sa22xmf/7 not heating at all after power turned off
SMEG SE435X-1 60CM Electric hob. Keeps tripping fuse
It's possible that one of the burners stay on for a long time, which cause one of the wires to overheat, breaking the connection and touching the body of the unit, please turn the breaker off and check for a loose connection, replace the wiring if you feel confortable doing it yourself or contact a technician.
Jan 06, 2010 | Smeg 23 in. SA435X Electric Cooktop
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range Logo
275 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
