Question about Whirlpool Washing Machines
Noisy/loose agitator the top half of the agitator has become loose and rattles around when washer is in use how do I remove it to check what is wrong
  • 958 Answers
Remove the top piece of the agitator. this is a dispenser. then remove a cap that is at the center of the agitator. there is a bolt there that is holding the whole agitator. remove the bolt and you can pull out the whole agitator. be careful in removing, the thing could just separate to pieces and you may have a problem assembling it again.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
Whirlpool top loading cloths washer agitator is loose when it should be turning. how do i tighten it?
Sounds like you might have bad agitator dogs. Remove the agitator cap, theres a 5/16th bolt that needs to be removed then the top of agitator comes off. The dogs are 4 little gears with teeth on them, when they get worn the top half of the agitator doesn't move.
May 09, 2011 | Washing Machines
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    WWSE3160AOWW A loose nut or something rattling around and can't get agitator off to look.
    use a belt to put under the agitator to decompress the clips on the bottom of the agitator. Pull up at the same time you decompress the clips.....carful not to knock yourself in the chin
    May 06, 2010 | GE WWSE5200B Top Load Washer
    Agitator clicks when agitating clothes. With part removed, top part seems to click when rotated around stationary bottom part. How can this get fixed? Can the top and bottom part get separated?
    this is the way it cleans your clothes
    if you take it apart it will not move your clothes around to get them clean.
    but yes it does come apart you have to hold the bottom down and pull real hard to seperate the 2 peices.
    But if you want my advice I wouldn't
    They are normally noisy machines.
    Feb 15, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
    Agitator loose
    lift out the softener cup located on top of the agitator,there is a 7/16" nut bolted down into the agitator spline that may have come loose
    Jan 16, 2010 | Washing Machines
    Kenmore elite sm 9710803-a motor
    Belt is loose or pulley needs to be tightened.
    Servicing the Tub and Agitator
    ©2006 Publications International, Ltd.
    Replace a damaged agitator
    with a new one of the same type.
    Unscrew the cap on top of the
    agitator and pull straight up;
    the agitator should lift off.
    The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
    If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
    The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
    Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
    If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
    Sudden tub stops can be caused by a broken motor belt, but they are usually due to poor tub loading. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
    Replacing Drive Belts and Tightening Pulleys
    The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
    Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
    Step 2: Remove the old belt and stretch a new one into place on the pulleys.
    Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
    Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
    Sep 04, 2009 | Washing Machines
    Ariston Margarita 2000 NOISY spin cycle....
    Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
    If it is o/k then check motor for worn or noisy bearings,
    Please rate my solution.
    Thanks.
    Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
    Agitator seems loose and agitates during the spin cycle
    HI, the actuator shift device in the transmission is malfunctioning. you will need to replace the transmission soon.
    May 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Very Noisy Operation
    you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
    Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    Clothes mover of whirlpool top-loading washer is loose. Agitates.
    You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
    Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
    Washing Machines Logo
    314 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
