Question about Canon PowerShot A630 Digital Camera
Lcd won't work when it is flipped and facing out in the back.
The lcd works fine when it is sticking out to the side but as soon as I flip it and click it into place to veiw it from the back it goes black.
  • swig33 Oct 14, 2008
    Thank you for your fast reply. Is that the only thing that could be causing the problem?
  • swig33 Oct 15, 2008
    Thanks, any idea how much something like that would cost to fix?
The flip out screen has a position sensor sensor. When you flip the screen towards the front, it tells the camera to flip the image vertically, so it would be normal. If it doesn't flip, the people in front will see the image upside down, which is due to the vertical rotation you made when flipped it out.
The other thing is that there is a small button in the corner of the bed where the screen lays into when not flipped out, and the screen itself is depressing this button. The function of this button is dual. It turns off the display, when it's facing inside, and flips the image horizontally when it faces towards you.
If the sensor goes wrong, it wont flip the image when you flip the screen towards the front, and the button will turn the display off, instead of flipping the image vertically, when the screen is facing you.
This sensor is placed in the hinge unit.
Posted on Dec 09, 2011
    Master:
  • 395 Answers
The flex strip is cut and thats why you are facing that problem ... please use it the way it works till you can ,,,,, when it completely goes dead have it replaced by a repairman ....
Posted on Oct 14, 2008
  • 1 more comment
  • Parshiv Luthra Oct 15, 2008
    Yes .... Because the LCD is a moving Part it is powered and communicated with a help of a Flexible Strip ..... Due to Usage and sometimes Obstruction the Strip Cracks from Inside breaking the connection as in your case .....
  • anamouse Sep 13, 2014
    The two previous commenters are not familiar with your camera, if your's is like all the others with similar mileage, it's the wires inside the cable that runs from the LCD screen to the back of the camera's main circuit board. Bad news is that even though that's very common, Canon won't fix it or sell you the parts to fix it, they want you to buy a new camera. It's not a flex strip, it's a small bundle of wires and the break is right near the flex hinge. The repair is not complaicated but impossible with the right part since it has pri proprietary connectors.
SOURCE:
My lcd works fine untill i flip upside down
There is may be a problem with your power cable. You need to fix it properly.
Jul 23, 2013 | Dell ST2310 23 inch LCD Monitor
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
Hatch won't close
you dont say which latch it is but check the part that latches on the stud sticking out. if its closed just pull open handle and manually flip the latch open an should work fine.
Oct 29, 2012 | 2011 Audi Q7
My Dell W3707C LCD TV won't quit flipping. The only button that works is the power button. I can hold the channel button down and flipping stops for about 2 minutes and then it starts flipping a
one of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
Oct 29, 2012 | Dell W3707C 37 in. LCD Television
Had new key intion on now my lights won;t flip up or down,
I would take it back to whoever did the install, and see if they will correct it. Is your light switch to flip up the lights on the steering column? Possible they pinched or inadvertently pulled a wire loose. I know on toyotas the flip up lights work off the light stalk, independent altogether of the ignition switch.
Jun 29, 2012 | 1993 Nissan 240SX
Printer worked fine. now picks up tons of sheets
A lot of people soon forget to "rifle" the paper before placing it into the bay. This helps prevent the paper from sticking during feeding. Just treat the paper like a book, and flip through the pages.
Jan 15, 2010 | HP LaserJet 2100tn Printer
Camera Turns off when Display is rotated then closed
ur strip line is broken dont use ur screen with more rotation
Jun 18, 2009 | Canon PowerShot SX10 IS Digital Camera
My blackberry pearl flip got wet
Sorry to tell you but the back light on your blackberry pearl probably burnt out. That is one of the most common issues with a wet phone.
You can find blackberry flip 8230 and 8230 LCD screen replacements on ebay. Took a while but they are available now.
They are a little tricky to replace but not to hard.
Checkout the guide I wrote for replacing the blackberry flip LCD displayscreen. There are also links to by the new pearl flip LCD screens2.gif
Blackberry Flip 8220 LCD screen Replacement Guide
May 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
Nov 06, 2007 | Sony Handycam DCR-SR40 Camcorder
LCD flip out screen
I had purchased SONY DCR HC 42 in july 2005. now i am facing a problem with the LCD display. whenever i open LCD screen nothing comes on it. view finder is working fine. kindly help me out Pritu
Jul 22, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
Canon PowerShot A630 Digital Camera Logo
273 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
