Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Stand by light flashes 6 times
Already checked c515 and 516 cant find ic206 on my sony kv36hs510
  • 1 more comment
  • lisamiw Oct 14, 2008
    mine flashes 7 times, turns on for about 5 seconds with sound no picture, then turns off
  • parvesh1303 Nov 24, 2008
    stand by light flashes 6 times what should i do , what is the remedy
  • lisamiw May 11, 2010
    How do I check the power supply regulation and horizontal circuts
  • 2,071 Answers
That blinks and flashing have a diagnostic code;
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
Now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking four times. This would tell you that you have no vertical sweep, which is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault. It's not a sure cure..
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition.
Hope it may help you;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Oct 14, 2008
STAND BY BLINKING LED 6 TIMES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. For more information go to http://electronicshelponline.blogspot.com/
Nov 23, 2013 | Sony KV-35S26 35" TV
My sony wega blinks the standby light red 6 times, pauses and repeats. Cant get a picture on it at all. Any ideas?
  • Sep 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Try to turn on, it turns off right away and the stand by light flashes 6 times
    Hi
    Thanks for using FixYa. Standby/Timer light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. Also check +5 line is overloaded (A, B boards), +5 line is shorted (A, B boards). Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jun 03, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
    Sony model KV32hs420 Powers on for 2 seconds than turns off and standby light flashes 6 times
    you have no horizontal output,with a ohm meter check C515 & C516, also check the jungle IC,IC206......... hope this helps.
    Feb 16, 2010 | Sony Televison & Video
    Sony WEGA lcd takes about 150 attempts to power on. Stand by/power light blinks 6 times and shuts off
    Hi
    Thanks for using FixYa. Red light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. If you want to do it yourself all this is only recommended if you have electrical expertise and know how to solder/re-solder components if not then you should always contact a qualified repair tech. for the same.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Dec 29, 2009 | Sony Televison & Video
    Sony model # KP-43HT20. power light flashes 6 times.
    hello o Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
    shaun
    Nov 08, 2009 | Sony KP-43HT20 43" Rear Projection...
    Stand by light blinks 6 times, wont power on
    Here you find sony blinking codes
    SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
    SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
    Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
    No power, standby light flashing
    SIX Blinks
    Jul 24, 2017 | Sony KDL-32S3000 32 in. LCD Television
    Sony tv repair
    I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
    Dec 22, 2007 | Televison & Video
    Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
    3,149 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
