Question about HP LaserJet 4L Printer
Print jobs hang - LED out of paper
I love my Laserjet 4L, but now it has a problem. When I send a print job to it or try to print a test page, a sheet of paper will feed part way then hang, and the paper light starts flashing. If I clear the hung sheet of paper and try again, same thing repeats. I've cleaned the feed roller but that didn't fix the problem.
  • 3 Answers
A 4L is fairly simple and has a short paper path. The pickup roller can be cleaned with a Q-tip and alcohol and usually helps. However if at sometime a piece of paper tore loose and stayed in the path that would be a common cause. All it takes is a piece of a corner or if you've used sheet labels in the past that could do the same thing.
If you feel comfortable digging into the guts of it, that may prove to be the solution. Let me know if you find any foreign materiel in the paper path.
Lanmster
Posted on Nov 17, 2008
    Genius:
  • 1,605 Answers
You need to change the ppeper pickup roller. cleaning some time helps, but always. When the same problem happen again and again. it is time to replace the part.
roller is about $8 each.
you can get it at http://www.feedroller.com/Store/index.php?cPath=1_17_86_25
HP LaserJet 4L quit working It's connected to my PC and it's on. All 4 lights are on; 2 green and 2 orange. When I try to print, the paper goes through but nothing is printed on the paper.
Empty cartridge maybe?
Otherwise it's simple: selt-test page(by printer button) printed ok - it's outer problem. Self-page is blank - it's inner problem. And so on... use Golden Section method
Jan 10, 2014 | HP LaserJet 4L Printer
When i power on my printer, its blinking indicating there is paper jam and no paper are in the tray, its also blinking at the part. kindly advice on how to go about it
if a computer is trying to send a print job, a no paper situation will make the printer think the paper jammed when it tried to pick it up.
Put at least one piece of paper in the tray.
If a page comes out, determine what computer is generating it, and kill the print job at the computer.
Then turn the printer back on and see if the error is gone.
Easier test - disconnect everything but power from the printer. have at least 1 sheet of paper in the tray. Power it up. If everything is normal, you need to track down the machine on the network that's trying to send a print job.
Mar 15, 2011 | HP LaserJet P2015 Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
HP Laserjet 4L just started printing black pages. After a few pages they print are normally. It all starts again when I begin another print job after some time passes after the last job. Put a new...
The image drum is not getting the correct signal at the correct time. It is time to retire the 4L and replace it with a newer, faster LaserJet. You'll be glad you did.
Nov 19, 2009 | HP LaserJet 4L Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
Feb 26, 2009 | HP LaserJet 4 plus Printer
HP laserjet 4L wont print from computer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | HP LaserJet 4L Printer
Paper jam error after last page prints
Hi Natoli3,
This could be a mis-match of paper sizes. Example, computer could be sending an A4 page to the printer. The paper size in the could be set to Letter. Ensure the 4 paper sizes match, in the computer - the document and printer driver; in the printer (change in control panel) and paper tray (adjust the physical side and length).
S88
Oct 23, 2008 | HP LaserJet 4100 Printer
reinstall the printer driver.
Windows operting system have the printer drivers. you don't need to download it.
if you really want to, goto HP.com>> service and support.
Oct 21, 2008 | HP LaserJet 4L Printer
Laserjet 5L Hangs on Single Sheet Input Jobs
This probably means that the document you printed is set to manual and the printer is waiting for input
try this:
print the document, when the data light is on, press the button on the printer, does it print? if yes go into word and under page setup set the printer to "Auto select" for the paper tray.
or remove paper, print, when the data light comes on, insert the paper into the single sheet tray
hope this helps
thanks for rating
Jan 16, 2008 | HP LaserJet 5L Printer
HP LaserJet 4L Printer Logo
109 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
