Question about Smeg A2.2 Gas Kitchen Range
Smeg Oven blowing
Smeg oven keeps blowing no electricity
  • 1 more comment
  • 14wishy Oct 15, 2008
    The ovens are electric and there is no supply reaching them.
    Sorry for the confusing title freetek. Basically the range is a dual electric oven with 6 gas hob burner. Nothing electrical is working, lights, clock ignition etc. The ovens have a single cable connected to a standard 13 amp fused spur which is connected to the fuse box via 2.5mm cable. The cooker cable connects to its own 32amp RCB in the fuse box. This did not trip when the cooker went off, is there anyway to check the RCB is OK?
    There is a cooker switch near to the cooker but this was obviously not used as the switch never switched of the cooker and the 13 amp switched spur did, don't ask me why as I inherited the setup when the house was purchased. The 13 amp fuse had not blown as I used it elsewhere to check.The cooker has worked faultlessly for 5 years, with sometimes both ovens up full throttle and all burners running.
    Is there possibly a fuse internally within the Smeg range which could have blown?
  • Anonymous Jan 17, 2009
    We have had the same problem. We have had the fuse replaced FOUR times. I keeps blowing out. The circuit isn't the problem as other things work on it. The oven is one a separate circuit with only a toaster and tea kettle sharing it. Neither were on when it began blowing out. Both still work.
    We've given up. Our Smeg is also 5 years old but now keeps failing. We are replacing it...but not with a Smeg!!
Phew! I'm very grateful for all that freetek but it certainly sounds like I may have a problem outside of my ability. I guess I will have to bite the bullet and get some expensive engineer to come in and sort it.
As a layman I just can't understand how it works fine for 5 years and without any alterations made simply stops! :-(
Thanks for all the advice, I will post back when and if I solve the problem, or wether in simply ends on the dump!!!
Posted on Oct 16, 2008
  • Smeg Master
  • 5,568 Answers
If the stove is vented to the outside, it may be just drawing air from the room through the fan.
Posted on Oct 14, 2008
  • Steve Allison
    Steve Allison Oct 15, 2008
    Sorry, the title included 'Gas Kitchen Range.'
    Have you or has someone else checked the wall outlet where the range is attached?
    Is anything electric working; Light? Clock? Control Panel? Top elements?
    Electric ranges are normally supplied with two 120 volt phases or a 220 volt single phase and any of those would be protected by fuses or circuit breakers located in the main breaker box.
    Perhaps you could have listed the things already checked?
  • Steve Allison
    Only by substitution unless you have a basement full of 'stuff' from a former business as I do or removing it from the breaker box bus and checking it externally.
    I don't know where you reside but in the US a serviceable digital multimeter can be had for <$20 US that will find many uses at home or on auto electrical puzzles.
    Most CBs when defective will not reset as normal when they are sick but to ensure the contacts are still conducting, abuse the CB a little by flicking it off and on several times.
    I don't think there would be internal fuses and if there were, I would expect one per oven meaning that you would still have one functioning.
    Another possibility is a GFI (ground fault interrupter) in the circuit which could be built into a wall outlet but wherever it is, it would have a 'Test' and a 'Reset' button.
    If either the switching circuitry or an element has developed a 'leak' to ground, GFIs will trip instantly (typically in 1/2 cycle) if a fault is present.
    Some devices as primitive as hair curlers have  them internal today and your oven may have one too.
    If you have any kind of meter available, check from each leg of the AC plug to any exposed metal on the range on a high Ohms scale (10K or more) to see if any elevated line (hot) is leaking to the chassis.
    GFIs need only a few hundredths of an amp to trip.
    I hope you find one plug contact that is shorted to any exposed metal as this would be a rather dangerous condition if the range had no earth ground.
    If you have already gained access to the heater elements, check those for continuity otherwise don't bother; it is nearly impossible that both would fail together.
2 Suggested Answers
  • 409 Answers
SOURCE: Smeg Oven blowing
do you mean it's popping the breaker? sounds like you need to check the electrical circuit for a TOD. it needs to be replaced.
Posted on Sep 13, 2008
Blows mains fuse
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
The fan only blows cold air and does not heat up any food.
Jun 13, 2011 | Smeg SE399X/5 Stainless Steel Electric...
Smeg A1 cooker built in. Wish to remove top to access thermocouple. Cannot see the fixings for the top. Any pointers please?
my smeg oven has always never worked properly, the temperature is faulty etc i now want to remove this oven and have bought a new electrical oven but cannot seem to get the smeg oven out. How do i remove this smeg oven?
Mar 20, 2009 | Smeg A1A.1 Gas Kitchen Range
SMEG SA410X-S heat not coming on for fan forced cooking. The fan and light work, and the heat works fine for grilling.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Mar 18, 2009 | Smeg SE399X/5 Stainless Steel Electric...
My smeg oven,(bottom fan oven) keeps getting hotter and hotter till it cuts out or the fuse blows when i switch it on no matter what temp i put it on,iam assuming its the thermostat,were is it and how yo...
The thermostat is obviously not working and you will need to replace it.
The thermostat is located behind the temperature selector switch on the control panel. The oven thermostat usually has a capilliary tube attached which goes in to the oven internally and is fixed on to the oven wall you will need to disconnect this also and remove it with the thermostat. Fitting the stat is the reverse of removal.
Make sure the electrical supply to the oven is switched off before starting work Hope this will FixYa.
Please remember to rate this solution.
Dec 12, 2008 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
Smeg Oven blowing
Dec 22, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg A2.2 Gas Kitchen Range Logo
1,170 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
