Question about Washburn Amplifiers: 25 WATT Guitar Amplifier - Bad Dog - BD25R Car Audio Amplifier
I have not played my electric guitar for months now there is no sound coming through the amp, the amp works ok
I have not played my electric guitar for months now there is no sound coming through the amp, but the amp works ok
  • 51 Answers
Probably have active pickups on the guitar.
if there's a plate on the back, get a small phillips screwdriver, take the plate off, and put a new 9 volt battery in.
Posted on Dec 04, 2008
I have a peavey VIP2 amp.Can I use my acoustic/electric guitar in the electric guitar setting
You can not only play it on electric guitar setting, you can play it LOUD. Its all about what YOU do and what YOU like. Dont accept it when somebody tells you that the music you're playing doesnt sound good to them. ITS YOUR MUSIC !
Do whatever you want. And NO it wont hurt guitar or amp. Rock on or whatever it is you do.
Oct 26, 2015 | Peavey Vypyr VIP 2 40W Modeling Combo...
Is it the guitar or the amp
Hi, Sounds like you have a bad cable to your amp. Try swapping out the cable. If that is not the problem, The pickup maybe bad.
Hope that helps.
Jan 14, 2014 | ESP LTD MH417 7-String Electric Guitar
I have a yamaha THR 10 guitar amp and I am using the 8 alkaline batteries to power it instead of pluging it in to the power inverter of my truck. I am a truck driver and got this amp because I want to play...
If it was electrical noise you could get a suppressor just like you would for a car engine. But it sounds to me that you are saying it's amplifying the actual sound of the engine. If this is the case there's not a lot you can do. As the amp is designed to amplify the noise of a guitar, which is noise in general, not an electrical signal. At least that's how understand how guitar amps work. Though I will stand corrected if I am wrong!
May 27, 2017 | Yamaha Audio Players & Recorders
Amp not comming on until strings played hard.
Check your cables - I've had similar problems with various amps playing various guitars; the guitar electronics and the amp electronics are fine, but the cable is damaged internally and this causes the same problems as you have described. Have you tried using a different cable? Buy a different one, try it out, and see if you have the same problem. If you have a friend who plays, let them plug their cable and guitar in the amp - if it works, your faulty cable is the issue. Hope that helps!
May 01, 2013 | Genz Benz Shenandoah 150lt Acoustic Amp...
I bought a Fender Frontman 212R back in March of this year. It worked brilliantly for almost six months, until July 26th, when during a jam session, the audio randomly cut out. Upon inspection, it appeared...
Try using your guitar cord to plug in and out of the headphone jack several times while unit is on. There is a circuit that disconnects the speaker when using headphones and the circuit is activated when something is plugged into the headphone jack. This "switch" can get dirty and cause the can get dirty and cause the problem you describe.
Aug 26, 2011 | Fender FM212 Solid State Electric Guitar...
D10sce will not work when plugged into the amp. the cord is nine ( works with my electric.) battery is new. when you turn up the volume on the controll, you can hear it in the amp, just no pick up sound.t
SUBSTITUTE Change the guitar for a friends to see if the amp is really OK. Try your guitar in a friends amp to see if the guitar is OK If the guitar is at fault its either the battery, the connection cord, the little pre amp in the guitar body (you can't fix that) or you have put nylon strings on the guitar which needs stell strings for the pickup to work. Good luck
Feb 13, 2011 | Washburn WD10SCE Cutaway Acoustic-Electric...
I've plugged my SX RST guitar into the SX GA-1065 amp but I can't get sound to come from the amp. I've made sure everything is plugged in and adjusted, but it still won't work. Why can't I get it to play?
Test the amp cable by plugging in the guitar cable an touching the end of the cord and you should get hum from the amp if the volume controls are up.
Many guitars require a battery to operate the preamp inside them.. Verify if yours needs a battery and it is fresh and properly installed.
These batteries are turned on by plugging in the guitar cable into the guitar. Leaving the cable in will exhaaust the battery, often within a day.
Sep 01, 2010 | Sx Guitars SX SST SE CAR + GA1065 STCAD...
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
Guitar hero world tour game has no sound all
check your disk for scratches or fingerprints.
Jun 11, 2009 | Sony PlayStation® 3 (60 GB) Console
Guitar amp shows power but has no sound, could it be a blown fuse
Nine times out of ten, any problem with an amp having no sound coming out, it's a wiring issue. Make sure all of the wires internal to the amp are propely hooked up. Also, try switching out the quarter inch cord you are using from your guitar to your amp. Could be a bad cable. Unless you have blown the speaker completely, something is loose or not hooked up properly.
Feb 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Washburn Amplifiers: 25 WATT Guitar Amplifier - Bad Dog - BD25R Car Audio Amplifier Logo
1,149 people viewed this question
Top Washburn Car Audio & Video Experts
xxxxxx xxx
Are you a Washburn Car Audio and Video Expert? Answer questions, earn points and help others
