Question about Xerox Phaser 8500/DN Printer
Problems with printer settings
When printing from excel to our Phaser 8560 DN my page setup settings with regards to scale and page breaks are all reset. This happens every time. At first I thought it was a bug in Office 2007 but now I have another printer as well (HP) and when printing to this printer I do not have the same problem.
Do you know what causes this?
Best regards,
Christina
  • 3 Answers
Interesting. I tried printing a simple 3-page Excel spreadsheet sent my by a colleague to my 8500DN from Microsoft's Excel Viewer and got a timeout error formatted as follows:
ERROR: timeout
OFFENDING COMMAND: timeout
STACK:
42
-mark-
(84,160)
No idea what this means, but resetting the network parameters (even though I use USB connection) from the printer's front panel cleared the problem. The printer would print nothing else from any program until I performed this reset. Wonder if Excel futzes with settings and printing somehow?
Posted on Oct 15, 2008
07, 010.43:35874 Error on Xerox Phaser 8560 MFP
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward tothe print position, due to problems.
1.Reboot the printer.2.Clean the print-head area (You should be able to manually push the print-head right to left.)
May 22, 2011 | Xerox Phaser 8500/DN Printer
My 8560 DN will not print 2 sided I have set 2 sided printing on the printer menu and specified it in the printer properties but it will only print single side pages
There is a website called "JustAnswer.com". You can ask them about the printer, and they will give you an answer. They have 7 techs available to help you. You have to just sign up with a user name and password, but it's worth a try! Good luck!
Mar 15, 2010 | Xerox Phaser 8500/DN Printer
Phaser 8560 error is print head out of position, how do I correct this problem
There are 2 problems that usually cause that.
1 is if you have had a power failure , or even not, the print head wiper blade tacks to the print head and does not allow it to move.
The other thing is the Print Head Block, a stainless steel block, about 1 inch square, located on the lower portion of the left side of the machine is contaminated with some ink and not allowing the print head to move freely.
Jan 12, 2010 | Xerox Phaser 8500/DN Printer
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
2 sided copying
You just select 2-sided printing in the print dialog box. I think it's on the finishing tab. I'm assuming you aren't trying to print on 2nd side of pre-printed stock. That would be a different issue.
Apr 09, 2009 | Xerox Phaser 8500/DN Printer
How do you print config sheet (mac address) from phaser 8500 pri
Here ya go.
NOTE: The Configuration Page can be printed to help solve printing problems and obtain the best results from the printer. Access this page from the printer's Control Panel.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Configuration Page], and then press the [OK] button to print.
  3. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main Menu.
Mar 17, 2009 | Xerox Phaser 8500/DN Printer
Install wiper on xerox 8560 dn
The user guide is available here http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=8560&Xlang=en_US&Xcntry=USA&prodName=Phaser%208560
Also, I think there are two wiper blades on the 8560, one is on the maintance kit and the other is supposed to be removed, that was the old 860 that could remove theirs. Perhaps cleaning it will be fine. just open the top of the machine and its right there, give it a wipe and it should be fine. The other wiper blade on the maintanance kit and here is a link below to show you how to clean it!
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=355,E=0000000001343253407,K=1300,Sxi=12,Case=obj(902)
You can use this site to troubleshoot any problems with Xerox printers.
Niallbt
Feb 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Feb 13, 2009 | Xerox Phaser 8560DN Laser Printer
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser  8500/DN Printer Logo
1,312 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
