Question about HP mx705 17" CRT Monitor
Solution explanation I don't understand the solution you posted for me concerning my monitor issues. This is what you posted: 1. Adjust the LOT screen preset. 2. Trace the G1 path , LOT to neck board. Sum times diode are capacitor problem. 3. LOT sarounds one 10Mf / 450 V capacitor bad What is the LOT screen preset and how do i adjust it? How do I trace the G1 path, LOT to neck board and what is the neck board? And I'm completely lost with the 3rd step??? Any chance you could clarify a little for me? Please? Thanks
I guess he meant the internal part of the monitor, prob on the pcb board .
Posted on Apr 08, 2009
I have an old hp v75 desktop that the monitor won't turn on all the lights are working, fan running, nothing wrong with the power supply, but when I press the power button it turns on, but the monitor...
First remove the vga cable from the desktop and see the monitor shows no conection if showing there is no problem with ur monitor if not change the monitor if showing conect the cable back to ur desk to vga port then check the ram remove the ram clean the surface with clean cloth then rub the print using an eraser then insert the ram and switch on if still no display change the ram if still not working remove the processor heat sink na clean th surface of the processor and the heat sink apply a thin layer of heatsink solvent or thermal paste fix the heat sink then restart the computer
Jun 29, 2012 | Computers & Internet
Tip
Beep Code Explained
Thanks to Transcend Technical Support for this great Brief of understanding beep codes that is found here
This is a long post and it may be truncated at the bottom. If so, use the link above to go to the Transcend web site where these are found
1.General POST (initial system boot) BEEP Codes
If you do not know the BIOS manufacturer, the following will be the general Beep codes:
• 1 Long and 1 Short Beep ?Bad Motherboard
• 1 Short Beep and nothing else happens ?Disk Drive/Video Related Problems
• 1 Long and 2 Short Beeps ?Bad Video Card
• 1 Continuous Beep or Non-stop short Beeps ?Bad Power Supply
• 3 Short Beeps - Bad Memory
2.American Megatrends Inc. (AMI) BEEP Codes
• 1 Beep - Memory refresh timer error.
Reseat the memory, or replace with known good modules.
• 2 Beeps - Parity Error
• 3 Beeps - Main memory read / write test error.
• 4 Beeps - Motherboard timer not operational
• 5 Beeps - Processor Errors
• 6 Beeps - Keyboard controller BAT test error.
• 7 Beeps - General exception error.
• 8 Beeps - Display memory error.
If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
• 9 Beeps - ROM checksum error
• 10 Beeps - CMOS shutdown register read/write error
• 11 Beeps - Cache Memory Bad
Beeps 4-7, 9-11
Fatal error indicating a serious problem with the system. Consult your system manufacturer.
Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
?If the beep codes are generated even when all other expansion cards are absent, the motherboard has a serious problem. Consult your system manufacturer.
?If the beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning add-in card.
3.Award Bios BEEP Codes
1 Long Beep: Memory problem
Explanation: There is a failure of some sort related to the system memory.
Diagnosis: The first bank of memory probably has a failure of some sort; this is usually just a physical problem such as an incorrectly inserted module, but may also mean a bad memory chip in a module. It is possible that there is a failure related to the motherboard or a system device as well.
• 1 Long, then 2 Short Beeps: Video error
Explanation: The BIOS is unable to access the video system in order to write any error messages to the screen.
Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. It can also be a motherboard issue.
• 1 Long, then 3 Short Beeps: Video error
• Continuous Beeping: Memory or video problem
Explanation: The system is producing constant beeping in no specific pattern, or a fast "ringing" sound.
Diagnosis: This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem.
• Other Beep Codes
Explanation: You have encountered an Award BIOS beep code I do not have documented.
Diagnosis: Award says that any beep patterns other than "one long followed by two short" are likely problems with the system memory. However, of late they have started adding other beep codes to their systems as well.
4.Phoenix BEEP Codes
• 1-1-3
Explanation: Your computer can't read the configuration information stored in the CMOS.
Diagnosis: Replace the motherboard.
• 1-1-4
Explanation: Your BIOS needs to be replaced.
Diagnosis: Got to your motherboard manufacturers web site and download the new Bios.
• 1-2-1
Explanation: You have a bad timer chip on the motherboard.
• 1-2-2 or 1-2-3 or 1-3-1 or 1-3-3 or 1-3-4 or 1-4-1
Explanation: Motherboards is bad.
• 1-4-2
Explanation: Some of your memory is bad.
Diagnosis: Go to Basic Trouble Shooting
• 1-3-1
• 2-_-_ Any combination of beeps after two
Explanation: Some of your memory might be bad.
• 3-1-_
Explanation: One of the chips on your motherboard is broken.
• 3-2-4
Explanation: Keyboard controller failure.
Diagnosis:
• 3-3-4
Explanation: Your computer can't find the video card.
Diagnosis: Is it there? If so, try swapping it with another one and see if it works.
• 3-4-_
Explanation: Your video card isn't working.
Diagnosis: Replace Video Card.
on Jan 20, 2009 | ASUS P5W DH Deluxe Motherboard
Cant log in
I understand that there are so many people having issues logging in to facebook. But don't worry I will do my best to help you with this concern.
First of all, I would to make sure first if what exact error you are getting so that I would be able to provide the precise solution to this issue.
Please let me know so that I could help you.
Thank you.
Aug 11, 2011 | Facebook Social Network
CANT GET POWER TO THE MONITOR
Would need more information on this but check that the cable of the monitor in question is firmly plugged in the electric socket and in it's back panel. Then press the power button on the monitor to see if it starts. If your problem is that you don't see an image but the monitor starts that's something else.
Don't understand why this is posted on the Motherboards section but please provide more details.
May 15, 2011 | Computers & Internet
My stand will not go back so I can attach the base...please assist
Hello and welcome to fixya.
I believe you are trying to assemble the monitor and you don't have the manual in hand so here are two links that might help you out:
1. The hp w1907 user manual - see page 13 for assemble instructions or page 22 (if you are looking to only adjust the monitor height).
2. An eHow.com brief explanation.
If you are looking for disassembling the monitor itself to repair it, please let me know so I can re-post another solution although there are a couple of youtube videos already online to show complete repair instructions for the specific monitor.
Let me know if this helped you at all for this.
**Don't forget to rate this solution**
Thanks.
Regards from FixYa.com
Apr 16, 2011 | HP w1907 LCD Monitor
I want drive definition to help me to print
We'd like to understand more about the problems you've been having. We don't have a good explanation on the kind of issues that you were experiencing since there was no specific problem indicated.
Please provide us more information and we
Mar 19, 2011 | Lexmark T430 Laser Printer
It is offline
We'd like to understand more about the problems you've been having with the printer. We don't have a good explanation on the kind of issues that you were experiencing since there was no specific problem indicated.
Feb 09, 2011 | Lexmark E260dn Laser Printer
How to rectify HP Hard drive error 100019
See this link for an explanation of the error code.
It will depend what you've been up to, whether this should concern you or not.
Other possibly pertinent links here and here., and instructions on how to reset bios here.
If you are concerned about the integrity of your hard drive, I recommend you run chkdsk c: /f or /r, according to the instructions here and here.
If you suspect malware could be an issue, I recommend these malware removal protocols.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2009 | HP Pavilion DV6700T Notebook PC
Terratec phase 22 problems with getting stereo sound
You must make stereo cable (adapter), from 2 mono outputs to 1 stereo.
Jun 16, 2008 | TerraTec Electronic PHASE 22 Sound Card
Broken Monitor
Hi Roeder, I have never heard of an LCD screen cracking from anything other than physical force, this is a first for me. It is possible since there is high voltage power in there for the backlight. In light of the sound I suspect a component failed, generated lots of heat real quick and caused the crack/failure. This is really unusual and you might try calling Gateway to see if they will replace it, especially if it is one year or less old. I would resist all temptation to open the LCD till you call Gateway. If they will replace it they won?t be happy to find you opened the case. Let us know how it works out and please don?t forget to rate this post.
Feb 02, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
HP mx705 17" CRT Monitor Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
