My coputer wont start
My computer wont boot up when i press the start button but the green power light at the back is on
  • stanley1981 Oct 14, 2008
    there is no noise whats so ever
    ok then thanks for your help
  • 45 Answers
Do you hear a whirring sound when you press your power button? Is that sound located toward the back of your computer? If so your power supply may be ok and your motherboard has failed. If you do not hear a whirring noise then your power supply has failed and you'll need a new unit. Take it in to a repair shop or replace it yourself.
Posted on Oct 14, 2008
  • Arthur Keech Oct 14, 2008
    Ok well as odd as that sounds it's a good sign. You'll still need to have a hardware repair but it should cost between $70-$140 depending on the size of your computer. You only need to have your power supply replaced and it sounds like your motherboard should be fine.
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
D600 laptop boot problem
The D600 is plagued with power up problems for 2 reasons. First the connector on the motherboard to the power button is very sloppy and after awile it breaks contact. If you put pressure under the docking port area and press the power button it may start. The second is the memory slots. I know you said you replaced the memory, but it is the slot that is a problem. Remove the memory and put 1 chip in "A", then press down on the chip while trying to boot the laptop. If this works then get a peice of foam or pad and place it on the chip. When you put the cover back on it will push down on the chip and should boot. Repeat this process for "B".
The green light does signify a charged battery! This is also a possible reason for not booting. Remove the battery and try to boot with only the power supply. A shorted battery will stop the laptop from starting up.
If all of this does not help then remove the battery and the CD Rom, then try to boot. Finaly if nothing helps you should buy a new Laptop or a used one on E Bay. You could get a used D600 on E Bay that has a good motherboard for cheap money and use your drives and LCD. I work on D600 and D800 all the time. Let me know how you make out!
Dec 09, 2009 | Dell Computers & Internet
I have a 3507 emanchines computer.When I push start button all it does is show green light clicking . Then it will stop and the white light will below will blink 7-8 times. The green light will click about...
sounds like an issue with your motherboard or something like that...try resetting the motherboard by unplugging the power, taking out the battery of the motherboard inside the computer and pressing the power button several times to drain the power. then put the battery back in, plug in the power cord and try to start it up. if it doesnt work then ur gonna have to contact emachines because ur mobo is either defective or broken...
Nov 12, 2009 | eMachines W3507 PC Desktop
COMPUTER WONT TURN ON when i press the button it goes green then quickly flashes blue then yellow then goes straight back to stanby
change the main wire look weather there is any problem in the main coputer wire slot
increase he ram even if you repair ir and don't increase the ram the same problem will continue after some days. the same thing happend to me please vote.
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
Will not boot
click here to find the details.
you may also like to click here
Oct 02, 2009 | Dell Inspiron 1501 Notebook
Canon pixma mp-610
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 19, 2009 | Office Equipment & Supplies
Hi guys my p.c wont boot! when I press the power on and press the front power button all the fans start running and the c/d rom starts trying to spin i.e the green light flashes 2 times every 5 sec's or...
Hi...
The problem that you have are same in common, if your cd room will not boot you need to first boot your cd room, you just go to the BIOS to first boot your cd room,, when you turn on the computer you need to press the delete key (or F2) after that, use the arrow key to select, chose the boot priorities, then you need to first boot your cd room, after the cd room first boot, press F10 to save, the ok
Good luck !!!
Regards
PCmania
Jul 09, 2009 | Gigabyte Computers & Internet
Wont boot fully boot up.
Try reseting your PS3. Turn your PS3 completely off by the switch in the back. Then flip the switch back on. Press on the power button and hold it until the green light comes on, beeps twice then the green light should go out, replaced by a red light. Then turn it on normally.
Nov 21, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
