Question about Furuno GP31 GPS Receiver
Furuno GPS 30 Receiver
I Blow a fuse each time i turn the unit on. Could I have a short in the unit. Could I have done damage because of hooking up the positive/negative backwards.
    Brigadier General:
  • 6,966 Answers
When the GPS unit was wired in reversed, a number of the electronic components would be damaged. However, in most units (but not all), there is a component specifically made to sacrifice itself to go dead in such event(s) other than the fuse. The is often called the reverse protection diode. This would normally be connected right after the power entry point after the fuse. In some designs, it would be after the power ON/OFF switch. Should there be no such diode, then next in line to be the most likely culprits would be capacitors, transistors, ICs, other diodes (specially zeners). If the trouble is basically limited to power supply, familiarity with electronic components and circuitry, use of a DVM and a soldering iron should be sufficient to initiate diagnosis and repairs.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 14, 2008
Furuno GaAs FET Front End 4 Tone Daylight Display - when closing the DC breaker for the rada unit, the 10 amp fuse blows. Don't have a schematic. Don't know the model number. There are no data nor...
unplug the radar from it and turn on the display. If that does not blow the fuse, then your problem is either in the cable to the antenna or the antenna itself. Start there.
Nov 10, 2010 | Furuno 1715 LCD Radar System GPS Receiver
My furuno autopilot 511 has a rudder reference unit which worked and then stopped displaying rudder position. I assumed it broke and replaced it. I still get no display. How can I clear the unit. I had a...
the rudder setup needs to be done. follow prompts, very common to be screwed up, read directions carefully and make sure that if it says steer hard starboard, it is hard starboard before you proceed! 847-746-0100
Jun 01, 2010 | Furuno NavPilot 511 GPS Receiver
I have bought a ICOM VHF m601 and I want to connect the furuno gps 31 to the VHF. Is this possible ?
Using the nmea output from your GP-31 to the nmea input on the VHF. Enable the GLL Sentence and make sure the port is set for nmea0183. Remember hooking nmea up it's positive to positive and neg to neg. Once that is done and you have a fix you should have lat and long on your vhf.
Mar 09, 2010 | Furuno GP31 GPS Receiver
May i upgrade furuno 1920 gps/ploter with radar
If it has a round radar plug in the back then the answer is yes and it already has radar support. However to upgrade your unit to the latest software you will need a dealer for that. It's a very tricky process and if not done properly, you can ruin the bootloader programming that starts the unit. I know of a dealer that does this if you want to check in with them. You can even send them the unit. Try www.mid-shore-electronics.com.
Jan 25, 2010 | Furuno NavNet vx2 1920C GPS Receiver
A furuno 1715 lcd radar was wired to battery backwords
internal damage to the display, fixable by Furuno, and probably economically feasible (guess $250 with round trip to Furuno)
Nov 17, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Furuno 1621 radar will not power up
With a voltmeter, verify that you are getting 12V at the plug end of the power cable. If so, check the fuses (there should be one or two fuse holders on the back). If all of that fails you will need to send it in to Furuno for repair.
Aug 22, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Radar install problem
the GP31 has an NMEA in/out in the power cord - out is yellow green in blue(or black) and white on the 1833 you will use data 4 typically which has an in and out also, same colors hook out to in and in to out, program and done
Mar 23, 2009 | Furuno 1833C/NT GPS Receiver
Furuno GP 30-35 GPS
je viens de prendre possession d'un gps furuno 30/35 Jje n'arrive pas a afficher ma route pour allaer d un point a un autre merci de m'aider
Jun 14, 2008 | Furuno GP31 GPS Receiver
Furuno gp31
i dont think you should have a fuse on the - wire its only a return to earth its like closing the stable door after the horse as bolted
May 11, 2008 | Furuno GP31 GPS Receiver
Furuno GP31 GPS Receiver Logo
285 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
