Question about Samsung HCL473W 47" Rear Projection Television
Samsung HCL473W - Doesn't turn on
It worked fine one day and then the next it wouldn't turn on. I had a repair man come and he suggested that I spend my money on a new TV. He pointed out a large module with cards or smaller modules sticking out of it and said the whole thing could be bad or just one of the cards. He's quoting anywhere from $300-700 for the repair. If I new what the part was that is bad I would order it and install it myself, but he never gave me a write up of his findings. My TV is only 6 years old which I think is way too early to send it to the junk heap. Any suggestions?
  • Pandora320
    Pandora320 Oct 14, 2008
    I missed the "k" in knew, sorry.
  • Anonymous Nov 18, 2008
    Set would not turn on...
    Repair man pointed out the Blue side cooling fluid has leaked out onto the board and done damage to the board...
    I've seen many questions about the blue side leaks. Seems like a known issue.
    Repairman said it would be $600-$800.00 to fix and closer to the $800.00.
5 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: Samsung SP42W5HFX colour misalignment
Hi. Did the ngineer say that it was problem with convergence pcb ? To be honest the lil git hitting the screen is more likely to damage the screen than convergence. Try going in to the menu then convergence & adjust red & blue to try & get the crosses white with no coloured halo around. Post on here with results your model of tv is pretty straight forward I work for an indepedent tv repair shop the manuals are easy to get hold of thats if he even needs one. Chris..
Posted on Oct 06, 2007
SOURCE: HC-P4752W - IC Replacement vs Convergence Module.
The colors weren't lining up correctly on my HC-P4752W which is only about 30 months old. I did a little bit of research and got ahold of the people at http://servicemanuals.vstore.ca/ They recommended replacing the IC's as well as the IC resistors. I purchased the replacement parts from their site and made the repairs myself. I should mention that I didn't have any previous soldering experience. The repair was easy and a complete success. You may find replacement parts elsewhere for slightly cheaper but what you won't find is the prompt and detailed customer service that they provide. They gave me there # and said to call if I had any questions before or during repair. I took advantage of their services and got answers every time I called.
Posted on Jul 07, 2008
ladywinn
  • 5138 Answers
SOURCE: Samsung HCL473w lamp
Call FOX 1-800-227-5369 they have Lamps
BP96-
Posted on Jan 02, 2010
  • 53 Answers
SOURCE: Samsung HL-S4266W 42 in. TV has a bad DLP module.
The part # all depends on which version of the set that you have. Take a gander round the side of your side. Right side, if memory serves. You should see a sticker with 3 lines. One for model #, one for serial and one for version.
On the off chance you don't see one, check around the left side of the screen and take note of the lamp code. Your version will probably be a PB01 or PB02.
Depending on the version, the part # changes. Either way, you're looking at about $200.00 for a DLP chip. That's just the chip mind you, not the DMD PCB that drives it, or the rest of the light engine that helps process that information. I have had, during the course of my career, replaced a DLP chip to address white spots on the screen and found that insufficient voltage from the power supply cause the issue in the first place, or that the light engine itself was a contributing factor.
If you were to replace the light engine itself, you would replace all three components here and guarantee yourself a solid repair. You would hit the LE, the DLP and DMD all at once by doing a light engine. Granted, the cost is substantially more, but it might be easier in the long run to swallow $600.00 for a completed set than to swallow $200.00 for a DLP chip that didn't fix the issue and now can't be returned. Plus, a light engine will literally take you 30 minutes to put in and be done. Maybe even less.
PS - Don't touch the surface of that chip. And when you remove the DMD, pull out the old DLP chip and insert the new one....you're going to have to have help. Someone is going to need to watch the screen while you manipulate the DMD--set on and running--to align it back to the aperture. Have fun.
Part #s: Version PB01 :
4719-001968
Version PB02:
4719-001981
Try partstore.com to secure parts.
Posted on Jan 22, 2010
Ecollier2012
  • 3459 Answers
SOURCE: samsung projection tv. tv went off, timer light is
Its probably shorted convergenc chips. You can get the parts and instructions from www.TvRepairKits.com
Posted on Feb 21, 2010
My Trane XE1100 air conditioner won't start at all, worked fine one day and the next it wouldn't come on
check breakers in breaker panel,I need more info.is it blowing air inside
Jul 01, 2013 | Heating & Cooling
My truck was running fine and got in it the next day and it wouldn't start.. I'm not getting any spark.
What year model is the truck? if it has a Tach then crank engine over if tach doesn't move then suspect a faulty crank sensor if it does move check power to coil. several other things this could be but this is a start.
Jul 14, 2011 | Dodge Dakota Cars & Trucks
I have a Samsung Tantus HCL473W, when adjusting the convergence the screen bowed and it smoked. Is it possible the power supply went out, or worse?
Itispossible that the high voltage module went out, and to have it repair you are looking at babout 500, at the lest, and if it was me I just buy a new LCD, prices have really went down.You can good to www.partstore.com and checkand see if they have a highvoltage, deflection module, for your set, Take care.
Jul 08, 2011 | Samsung HCL473W 47" Rear Projection...
Home swtch not working 3g
iOS or jail broken? You need to determine if it is a software or hardware problem.
Connect your phone to iTunes and backup and do a restore to factory settings. If the button still doesn't work you could follow directions found online for opening your phone, but unless you know what you are doing I wouldn't recommend it. The odds that you could see something physically wrong and repair it are low.
If resetting the software doesn't fix it, you could send it to Apple to repair, but if it's a 3G you should consider not spending the money on the older model and instead put it toward a new phone.
May 04, 2011 | Apple iPhone 3G
I tried turning the main oven on and it didn't heat up and had gas odor. Side oven and burners were working fine. Next day, tried again and it worked no problem. Next day, same issue.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 16, 2011 | Thermador PD486GEBS Stainless Steel Dual...
BP96-
Jan 02, 2010 | Samsung HCL473W 47" Rear Projection...
A printer repair man fixed our deve error. took
maybe the printer repair man guarantees his work? i would be telling him that sijnce he fixed it this problem occured.
Jun 23, 2009 | Samsung CLX 3160fn All-In-One Printer
Convergence circuit correction
BEWARE some people suggest that the IC's can be replaced and that they are part of the convergence circuit, they are on the POWER board for the convergence circuit, the convergence is a separate 'card' that is almost the same price as the 'sub board' with the IC's. Although most people favor the sub board as the culprit.
Jan 21, 2009 | Samsung HCL473W 47" Rear Projection...
I need to really find an HCL473W tube, can you help me??
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
This requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Apr 19, 2008 | Samsung HCL473W 47" Rear Projection...
Samsung HCL473w picture distortion
easyab
Feb 18, 2008 | Samsung HCL473W 47" Rear Projection...
Samsung HCL473W 47" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
