Question about Acer Aspire 2001WLCI Notebook
I need bios version 2.0...
How can i get and install? and does this make any problem in my pc
Bios mod request
F-2 to enter BIOS
ACER has regular updates in BIOS, see acer.com support
May 28, 2014 | Acer Aspire 7741z
Bios update
How to Update Your BIOS
By Patrick Miller, PCWorld
  • Jan 21, 2010 6:00 PM
  • Check your BIOS version, without restarting your PC, by using msinfo32.exe (as described in the text).187437-versioncheck_original.jpgThe easiest way to find your BIOS version is to open up the System Information app in Windows--just type msinfo32 into the search bar (for Windows 7/Vista) or the Run box (XP), and clickSystem Summary; your BIOS version should now show up on the right under your processor speed. Record your version number (and the date that appears afterwards, if applicable).
    Step 2: Check your PC/motherboard manufacturer\'s Website for BIOS updates.
    Most PC manufacturers handle BIOS updates based on your specific line and model, so head over to your manufacturer\'s support page and check its listings for your PC, because if you download and install a BIOS intended for a different model, your PC probably won\'t work (although most BIOS updaters are smart enough to notice if you try to install them on the wrong hardware). If there is a BIOS update file available, grab it--along with any documentation it comes with, because often warnings and specific instructions are contained in the Read Me docs.
    Those of you who assembled your PC yourself will need to look for BIOS updates from your motherboard manufacturer\'s Website. If you don\'t remember your motherboard\'s model number, you can look it up without opening up the case by downloading and running CPU-Z and clicking on the Mainboard tab.
    Step 3: Read the included documentation.
    Your PC\'s BIOS handles a lot of the nuts and bolts ISO Recorder for Windows XP or the version for Windows 7/Vista) to create a BIOS update CD.Other systems will have you copy a few files to your bootable disk, restart, and open up the BIOS during startup (typically by pressing a specified key for setup options), and change the boot order so your system looks for a bootable USB drive or CD before loading the OS from your hard drive.
Dec 13, 2013 | Acer Q45t-am Motherboard Intel Q45 Ddr3...
Bios update version for hp a1420n
keep the flash drive in hand. try to install xp. while install it was asking for bios update and ask for press f8 for bios update and insert pen drive and select the path it will automatically update the bios and start installing
Apr 03, 2012 | HP Pavilion a1420n PC Desktop
My computer does not have sound unless it's plugged in
First check if the Vista Service Pack 1 or 2 is installed in the Computer and what is the version of the BIOS installed in the Computer.
To check the information about the Service Pack installed in the Computer:
Click on Start, type WINVER in the Search area and then press the Enter key.
Or
Please goto Start Menu, select 'All programs', select 'Accessories' to access 'Run' option and enter 'WINVER' and check whether Windows Vista SP1 or 2 is installed in the Computer.
To check the version of the BIOS installed in the Computer:
Click on Start, type MSINFO32 in the Search area and then press the Enter key.
In the System Information window check the BIOS version.
If the installed BIOS version is not R0231Q0 or higher then install the BIOS update in the Computer from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR190E&upd_id=3745&os_id=28
This is a known issue with a VGN-CR series Computer when Audio may not work properly after installing Microsoft Windows Vista Service Pack 1 (SP1).
Installing the BIOS update should resolve the issue.
If the issue still persists after installing the BIOS update then you may try installing the Audio Driver from this Link.
NOTE: Please first go for the BIOS update as it is a well known issue with a VGN-CR series Computers.
If the issue still persists, follow the steps as mentioned on this Link to resolve the issue.
Good Luck!!!!!!!!!!!!!
Nov 14, 2009 | Sony VAIO VGN-CR190E/L Laptop PC Notebook
No sound coming on my laptop VGN-CR220E
Please first check whether the Vista Service Pack 1 or 2 is installed in the Computer and what is the version of the BIOS installed in the Computer.
To check the information about the Service Pack installed:
Or
If the installed BIOS version is not R1121Q0 or higher then install the BIOS update in the Computer from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCR220E&upd_id=3618&os_id=28
Oct 26, 2009 | Sony VAIO PCG-K23 Notebook
Need the atg d630 bios chip number
Get the sofware CPUZ and it will tell you the chipset version and mainboard type.
Oct 06, 2009 | Dell Latitude ATG D630 PC Notebook
Hello , i have made update to my DG31PR bios , the new update version is 0066 ,,, after update the pc cant enter the windows and i have intel Pentium 4 processor 3.00GHz / 2m ,, after that i return the...
you have no need to update or upgrade your bios version anywhere if it work properly, but now if u have prob wid it,
1. try any other processor (P4, Dual Core, Core 2 Duo e.t.c)
2. reinstall any other version (0066 or 0052), just change the way of installation (this time install it from Floppy drive or other one, which is different to the 1st time u install from)
Jun 13, 2009 | Intel DG31PR Motherboard
BIOS PROBLEM
The file you downloaded should have provided instructions for its use wither in a redme file or on the page it was downloaded from. There are several different ways for flashing the BIOS. Many still require booting from a DOS disk and using a DOS-based flash utility to perform the update. Others are Windows executable files that can flash the BIOS directly without having to start a reduced-functionality environment, but they require Administrative access to the computer to perform the update.
If what you downloaded was a Zip file, there should be instructions included with it.
You also want to make sure that it the the correct BIOS you are flashing. If it is not the correct version, you risk permanent damage to your computer.
May 26, 2009 | AMD Athlon 64bit -3000+ Multimedia...
Notebook heating problem(urgent help)
You bios versions start at f.03,f.04,f.05, f.07, f.08,,,
The date and version that you posted does not match and bios version for your model.
The only reason you update a bios is if it falls under the problems
listed for the new bios to correct.
Say your lap came with f.05, the only reason you would update to f.07 is because you had a graphic error,that the new update fixed.
The link below is the page for your drivers, if you look at bios,it shows the newest,if you click on version,you will see all the ones
that where made.
You should double check to make sure that you have the right bios version.
http://h10025.www1.hp.com/ewfrf/wc/previousVersions?softwareitem=ob-61399-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=3646603
Apr 14, 2009 | HP Compaq Presario F750US
Acer Aspire 2001WLCI Notebook Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
