Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
WD portable 250 gb drive w/20 gigs of pictures
My WD portable 250 gb drive is broken and I have 20 gigs of important pictures there
    President:
  • 1,901 Answers
Is it truly broken or just not working, ie, not being recognized?
If it is broken, there are companies who specialize in data recovery.
One site is:
http://www.harddiskrecovery.net/
I've never used such a service, but they will give you a free quote.
Posted on Oct 14, 2008
How do i unlock the password on my wd portable passport 750GB??
Unfortunately Western Digital say that there is no way to reset the password on their passport drives.
Jan 16, 2011 | Western Digital WD Passport 250GB Portable...
Why wont my Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive work?
Several possibilities:
* bad USB port in your computer (try another USB port)
* messed-up copy of Windows (try connecting to a different computer)
* damaged USB cable between computer and the Passport (replace it)
* bad disk-drive inside the enclosure (replace it)
* bad USB-to-disk-drive adapter (buy a new "empty" enclosure)
Check the warranty on it, to see if W.D. will replace it, at minimal cost to you. If the warranty has expired, W.D. has a "Customer Loyalty" program -- buy a new Passport through their web-site, and you qualify for a discount on your purchase.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
Lost pictures
Depending on the exact failure, you have a couple of options. A friend of mine had a similar drive with important photos an it turned out the drive itself was OK, the enclosure had failed. I removed the drive from the enclosure, and connected it to another system with a drive adapter, and recovered the data.
If the actual HDD in the enclosure failed, you can contact a data recovery company like www.drivesavers.com and get an estimate on data recovery (Generally very expensive, just depends on the importance of the data)
May 25, 2010 | Western Digital WD Passport 250GB Portable...
If the disk drive of my WD portable drive failed, can I recover the data?
yes, you can connect disk drive to another computer, and then use some data recovery program to recover your files. you can download this file recovery software called asoftech data recovery that helped me before
http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Data-Recovery.shtml
May 03, 2010 | Western Digital WD Passport 250GB Portable...
I have new wd external hdd 250 gb, its not detecting on my desktop.
Is the drive formatted? Did you get an install disk supplied with it? If so try running it.
Check your system BIOS and see if the drive is being detected there. Also you can check the Device Manager in Windows to see if there any issues with the drive.
Sep 12, 2009 | Western Digital WD Passport 250GB Portable...
Local disk error WD My Passport 250GB
Do you connect & disconnect the drive according to WD's recommendations here? Try another cable. (If yours was wearing out, that might explain why it only connected some times.) Try another usb port. Check the power supply (another receptacle) Unplug other usb devices from the system.
See this article. Good luck!
Aug 18, 2009 | Western Digital WD Passport 250GB Portable...
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
231 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
