Question about Casio DR-250HD Calculator
Changing the ribbon
I am having difficulty opening the cover so I can change the ribbon
I don't think it's ever been done and this machine is more than a few years old and understandably hard to read now.
I don't want to break the cover, but is there some trick or perhaps something is jamming it internally?
  • 55 Answers
I just had the same problem today except I needed open because of a paper jam. Anyways, I started by using a philips head screwdriver and pried by where the plug is and worked my way around. The cover is held on by the screws on the bottom and some tabs inside. You kind of have to pull if open as it is very stubborn. Good luck!
Posted on Jan 12, 2009
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
I have a Rancher 455 chainsaw - when changing the chain the brake did not disengage and now I can not get the clutch cover back on - any suggestions?
I have done the same exact thing myself. It's not going to be easy. I had to compress the spring by hand. there should be a little cover screwed down covering the spring, carefully remove it. this spring is pretty strong, so if you let it out of the channel its in, it probably going to eject across the room. I don't think theres a specific method, just use ingenuity and force the spring to open up the ring that grabs the oustide of the clutch, and move the mechanism inside to lock it there, then re-cover the spring, line up the 3 notches, and it'll go right back on. Don't be surprised if it takes a little while.
Oct 16, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Got new printwheel.. Don't know how to release the old one!
Can't see the machine very well from here but I assume it's a typewriter. Poor eyesight, see?
First, turn the typewriter OFF, then slide the carrier to the center. Not because of magic, but it makes easier to work that way.
Now lift the cover, remove the ribbon, and on the right side of the solenoid you'll see a little lever.
I think it's the same you use to release the printing head when you're installing a new ribbon.
Press on it again and the old printwheel will just pop right out.
You should see a little elongated hole on the printwheel, so align it with the little stud and press. Gently but firmly.
Of course, reinstall the ribbon, push the assembly towards the platen until it locks in position, close the cover and turn the typewriter ON.
Jun 01, 2011 | Office Equipment & Supplies
How do i change the belt on the eureka 4703D
Changing the belt is quite easy on this unit.
First, you will need a phillips screwdriver looks like the X. there should be 2 screws on the top cover, and then MAYBE one more there by the hose where it attaches to the base at the back. The top cover comes off and you have full access to the belt underneath.
Also, side note, once you have the cover off there you should see a black and yellow sticker near where the belt rides, and it will go into more details to changing the belt.
Nov 03, 2010 | Eureka Power Plus 4703D Bagless Upright...
HOW DO I CHANGE THE RIBBON?
You can use the below link that will take you to the brother FAQ website. Follow the FAQ to change the ribbon.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000500/000045/faq000545_001.html?reg=us&c=ca&lang=en&prod=fax575_us&Cat=7
Thanks,
Pat
May 13, 2010 | Brother FAX-575 Plain Paper Thermal
Very limited directions for changing print cartridge. I changed it out the way I THINK IT GOES. Makes ratcheting noises and says to check cartridge. What did I do wrong? Need more complete directions.
Try these instructions. If you are still unsure, you may need to take it to a service center for cartridge installation:
WARNING: Be careful not to cut yourself on the sharp edges of the metal part shown in the illustration.
1 Push the OPEN button to open the top cover.
2 Remove the stopper from the printing cartridge.
3 Turn the black spool on the right clockwise to tighten the ribbon.
4 Install the printing cartridge by inserting the recessed c5b8824.jpgfirst and placing the cartridge into its four holders.
5 Press down on both sides of the cover to close it securely.
Oct 10, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Sony UP-DR150 4x6 "ribbon error"
The black spool of the ribbon has a built in chip, If that chip is damaged it renders the ribbon unuseable. Be very careful if you take out party used ribbons and re insert them later.
Dec 15, 2008 | Sony UPDR150 Thermal Photo Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Zebra s600
The factory default setting for the S600 is thermal transfer (ribbon). depending on your OS there is a command that can be echoed to the printer to change the setting to direct transfer (non ribbon). It sounds like your printer thinks is should use a ribbon and in fact you are not using a ribbon. Here is the procedure I use to get the ribbon motor to turn on:
1. start with the printer turned off.
2. open the printhead, retract the ribbon completely onto the supply spool. leave the printhead open.
3. Press and hold the top three buttons (PAUSE, FEED and CANCEL) while turning on the printer. When the botom couple lights turn off release the buttons.
4. When you are left with the power light on and the printhead light blinking reinstall the ribbon and close the printhead.
The printer will autoclaibrate and run a sensor test.
Once complete the take up motor should have turned on and you should be able to use thermal transfer labels and a ribbon.
Nov 21, 2007 | Zebra Stripe S600 Thermal Label Printer
Hot to change ribbon on sony m8800
Its not too hard to change. I have done this once before. Open main unit. Remove cd mech to get to the other end of the ribbon. Remove this end first. Manually rotate the motor worm gear until screws on head unit are visible. Install ribbon in head unit then main unit. Make sure the ribbon contacts and ribbon are positioned/routed the same way. Rotate that motor (end to end) again to see if the ribbon hangs up anywhere.
Nov 05, 2007 | Sony CDX-M8800 CD Player
Casio DR-250HD Calculator Logo
388 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
