Question about HP LaserJet 9050 Printer
Sleep Mode Is there a way to turn off the sleep mode feature on an HP 9050
Under the "RESETS" menu there is an option to "turn off" Sleep Mode.
Posted on Sep 01, 2010
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Laserjet 1536dnf mfp not waking out of sleep mode
Disable sleep mode or update firmware. Cause this is a firmware bug.
Nov 13, 2013 | HP Laserjet M2727nf Multifunction Printer
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
Monitor reading power lockout when try to shut off
the PC never turns off power to the monitor, it has its own power.
and sure, the monitors all do that 2004 to now. called VISA sleep.
modem has nothing to do with this.
Some monitors have this features called that.
its in your users manual. 2009m?
your page.
https://support.hp.com/us-en/product/hp-value-20-inch-displays/7274733/model/3884700/manuals
the words are clear.
it has power saver mode, turn that off
it has osd LOCK,
but no powerlock. as some do,. as your manual. shows.
page 24 shows.
http://h10032.www1.hp.com/ctg/Manual/c01725831
quote, power button does this.
turns the monitor on and to standby or sleep mode.NOTE:
The power button is located on the top or front of the monitor depending on the model
off , on, and sleep.
my guess you are putting the power button i Sleep mode
a feature of this monitor.
Aug 24, 2017 | HP 2009M Monitor
Computer will not wake up from sleep mode
- your comp is in hibernation mode
- go to control panel>>power management>>put to NEVER the sleep mode,hibernation,HDD,battery
- restart system
Mar 25, 2010 | HP Pavilion dv2000t Notebook
Curious - What is the moon shaped key all about
this button puts the computer into sleep mode.
FROM WIKIPEDIA-
Sleep mode can go by many different names, including Stand By (Microsoft Windows 95-Server 2003), Sleep (Mac OS 8)-(Mac OS X) / (Windows Vista,Windows Server 2008), and Suspend (Linux). When placed in this Sleep mode, aside from the RAM which is required to restore the machine's state, the computer attempts to cut power to all unneeded parts of the machine. Because of the large power savings, most laptops automatically enter this mode when the computer is running on batteries and the lid is closed.
Though Sleep and Hibernate are generally thought as two separate functions, modern Macintoshes, Windows Vista (termed Hybrid Sleep), and some specially configured Linux machines also feature a variation of Sleep mode that incorporates the strengths of Hibernate. The RAM is copied to the hard drive before sleep mode is initiated, preserving the RAM contents in the event of a power loss.
ACPI is the current standard for power management, superseding APM and providing the backbone for sleep and hibernation on modern computers. Sleep mode corresponds to ACPI mode S3. When a non-ACPI device is plugged in, Windows will sometimes disable stand-by functionality for the whole operating system. Without ACPI functionality, as seen on older hardware, sleep mode is usually restricted to turning off the monitor and spinning down the hard drive.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 04, 2009 | HP Computers & Internet
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Mar 19, 2008 | Computers & Internet
HP LaserJet 9050 Printer Logo
2,263 people viewed this question
Seeker5211
Seeker5211
