Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink System failure
Error 0xc18a0201
  • 3 more comments
  • acote Oct 14, 2008
    I have tried to turn off, unplug remove all cartridge.....does not work :(
  • acote Oct 15, 2008
    Ink system failure 0xc 18a 0201
    Ginko
    I don't understand when you say... "plug the power in"
    You mean I should unplugged the printer before I hold both buttons?
    acote
    done the procedures from hp document....still have the same message
  • 905 Answers
If these steps don't work then the unit will need to be serviced
The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition. Solution one: Reset the product Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Posted on Oct 15, 2008
  • jason Oct 15, 2008
    leave it unplugged for a while
    ( including the usb) one of the chips are locked up and all capacitors need to discharge there power before it will reset
    you could also look to see that the wire strip to the printing cartrige is properly plug or seated in
    Master:
  • 763 Answers
Try to uninstall your printer from your computer then restart the pc and then install it. see what happens.
CHARCOIS
  • HP Master
  • 19,396 Answers
There is a reset procedure that you should try, I will post it here.
  • 2 more comments
  • Ginko
    Ginko Oct 15, 2008
    Try the following reset:
    Hold the OK and the Help button at the same time. While holding them down, plug
    the power in. Continue to hold both buttons until the unit shut off.
    After shutting down, release both buttons and power on the printer.
    Let me know how it goes.
  • Ginko
    Ginko Oct 15, 2008
    Alternatively follow instructions on this document from HP.
  • Ginko
    Ginko Oct 15, 2008
    Yes, sorry, you have to unplug power to start the reset, if thet did not work, follow instructions from HP here: document from HP.
    You can also try a different set of cartridges if you have one, or try cleaning with isopropyl alcohol the metal plate contact inside the ink cartridge.
    If that still does not work, that means the really is really faulty (ink pump), in this case I suggest calling HP for support.
  • Ginko
    Ginko Oct 15, 2008
    More : if there is no real fault, but the printer is stuck with the error message, my first solution should reset and clear the error, I used it many times and it works, see here.
    When it does not work, usually that means that the printer is faulty.
I have an error message on my HP Photosmart C5180 All-in-One printer stating: Ink system has failed. Unable to print. Refer to printer documentation. Error: 0xc18a0201
Hi!
Ink System Failed is displayed becuase the printer head can not communicate with the main board of the printer and this can happen due to print head failure there is nothing you can do except repairing the printer.
Aug 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Error Ink System Failure 0xc18a0201
remove the ink cartridge and print head and then do a power drain. after that insert the print head and ink cartridge.. if it still shows the 0xc. error try by replacing the print head .. first
Jul 28, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP C7280
Hi there It worth a try nothing to lose and it may work. Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 02, 2010 | HP Photosmart C7280 Laser Printer
Hp 3310 error 0xc18a0201
if you are a tech and have opened one of these before, clean the service station on the right side, oil the carrage rod. time about 1.0 to 1.5 hours. most of the time this is the problem on inkjets.
Feb 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart printer Ink System Failure Error 0xc18a0201 happens every time I start it.
You press the button to turn off the printer.
Unplug the power cord from the back of the printer. Unplug the power cord from the back of the printer.
Remove all the ink cartridges. Remove all the ink cartridges.
Wait two minutes. Wait two minutes.
Plug the power cord into the back of the printer. Plug the power cord into the back of the printer.
Press the On button to turn the printer on. You press the button to turn the printer on.
Install the ink cartridges when prompted. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the error code does not display, the issue is resolved.
Dec 05, 2008 | Computers & Internet
Says Ink system failure
Here are the steps that i want you to follow exactly to resolve your isse.
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. Thank you so much. adonscott
Jul 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink supply system failure on a d610 hp printer
hey I have a hp photosmart 8250 inkjet printer problem i need to know if I can fix from home myself are do i need to take it to a shop Error code: 0xc18a0201
Apr 25, 2008 | Office Equipment & Supplies
HP Photosmart C5180 All-In-One InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
