I am trying to install "Canon Fax INF Driver v8.60 for 64-Bit Windows 7 Server 2008 Server 2003 XP Vista" driver downloaded from Canon's support site. None of fax machines referenced during the driver install include the LC730. Which fax machine am I to use that will allow the 730 to function correctly? I have installed the printer drivers for the 730 and the unit works correctly as a printer. Nick
SOURCE: Sharing Canon Pixma ip3000 photo printer with Vista from XP
On Vista machine, Go to Control Panel. Choose printer. Then choose Add Printer.
Choose
Add a local printer. Click on Create a new port. The default in the
drop down box is Local Port. Do not change that. Click Next.
A dialogue box will appear asking for you to enter a port name. Type in the \\computer name\printer name
Testimonial: "That did it! Thank you so much!"
SOURCE: Windows 7 and Canon LBP 800
if canon has a windows 7 driver, go ahead and say yes. it is just saying that it doesn't recognize it and it may not be compatible. If there is no windows 7 driver, use the one for Vista. The ones that run on Vista are 99% running on 7. It's a great program. Make sure you download the correct bit though, either 7 32BIT or 64 BIT, this is important! (alternatively, use vista 32 or 64 if needed)
SOURCE: Canon Pixma ip5200 under Windows 7 - not responding
Did you download the latest drivers from the website? It looks like they were posted this month. I would report the issue. It is quite likely there is a compatibility issue. Have you contacted canon at all about this problem? Once I have more information I can try and assist you further.
Thank you,
Lee
Also check out my tip on how to save money using less ink:
http://www.fixya.com/support/r3954871-save_money_using_less_ink_when_printing
SOURCE: cannot get scanner on Canon
Hi, please get new driver here:
www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay mqdg
SOURCE: I cannot install the (XP) driver for my Canon
the "mpmaster.ex_" file is a compressed file. It must be decompressed before it can be run.
