Question about Philips 42FD9954 42 in. Plasma HDTV
Philips PLASMA TV 42PF9956/37 42" power board 3104 313 60173 relays clicking TV does not turn on
I have a Philips PLASMA TV 42PF9956/37 42" that does not turn on . I checked the web site solutions and "pizzaguy" suggests to heat these relays with a hair dryer to have the TV back to work. Well, I tried heating them and the TV worked for a few hours only and now is clicking relays again. Alternatively "I AM I" sugests replacing the capacitors 2508 (4.7 uF @ 50v) and 2540 (100 uF @ 25v) My TV's power board is part nbr 3104 313 60173 and the 2508 and 240 are not capacitors. My poor electronics knowledgedid not recognize them. They are equal components, marked P3 100 16v on top. I also searched the board, but I couldn't find any capacitors at that values. pics attached.
  • 6 more comments
  • Marcelo Gomes
    Marcelo Gomes Nov 27, 2008
    Thank you cluxdelux. You are the best!!! We replaced the capacitors and the TV is working good. Instead of buying 100 pieces @ US$15 + S&H from the link you sent, we went to garret web site and found 50 pieces @ US$10 + S&H (that is their minimum order). As we only used 4, we have 46 capacitors left for anyone else who has the same problem, since I know how it hurts.
  • ismailayoub Dec 11, 2008
    I have this problem, my philips plasma tv 42pf9956/37 does not start, and i wish to fix it. i have no background in electronic. do you know someone in toronto to fix it
    ismail.mona@rogers.com
  • Anonymous Jan 14, 2009
    my power board went out and i sent it to a repair shop. what would something like that normally cost ,there looking for $481 all in with everything.any sugestions would be greatly appriciated,thxs
  • joeyley Jan 20, 2009
    my uk philips 42" went off and came back on again. then the on/off switch stopped working and of late we had to switch it on at the socket, somtimes it worked all day other times it took up to half an hour to get it to fire up. Now it does not work.I know it has to of gone down on the power side and reading this thread it seems this could be the answer. I noticed this fault is very common with nearly all plasmas.Help.
  • parisfor2 Feb 18, 2009
    i have the exact same problem with the exact tv, a phillips plasma model, 42PF9956/37. how do i order the capacitors? what are the part numbers? how many do i need? can i take the parts and tv to a repair person and tell them to replace the parts? do you know how much that would cost? i'm not very "techy" :>
  • akelly76 Feb 24, 2009
    I have the same problem with my 42PF9956/37 42". I just ordered the Rubycon capacitor. Can anyone give me a quick "how to" on replacing the capacitor? I am a novice at soldering. Will replacing this capacitor be difficult?
  • Anonymous Apr 04, 2009
    when i turn on the tv the screen starts to light up, but then shuts off. The green light turns red and starts flashing
  • malv1 May 11, 2010
    john3012
    Were the caps labeled right? How did you solder them, with iron or paste? I am looking for a little guidance. I have experience soldering just never on a tv circuit board before. Thanks Nick
The capacitors for 2533,2540,2541,and 2508 should be replaced. They are all 100uf 16v surface capacitors. Those capacitors are sold on amazon.com http://www.amazon.com/Rubycon-Electrolytic-Capacitor-IMPEDANCE-Continuous/dp/B0015A8U9M/ref=sr_1_2?ie=UTF8&m=A6Q8GCHJGURD6&s=industrial&qid=1225140147&sr=1-2
Posted on Oct 27, 2008
Mrgomes is there a way to purchase some of those caps off of you? I cant seem to find anyone who has them in stock. Thanks
Posted on Jul 21, 2009
  • ashmouth Aug 11, 2009
    I found an equal cap thats easier to get, it fits and works perfect, i got them from Digikey the product number is pce3750ct-nd
Cluxdelux solution worked!!! Soldering the surface mount capacitors was a lot easier than I thought especially considering that was the first time I ever solder. I do recommed checking out YouTube for quick soldering lessons. The only thing I wish I would of done different is purchased a soldering iron that was a little thinner. It was tough getting to capacitor 2508.
Highly recommend this solution. I just looked at another 42 at Best Buy today for $900. It is hard to believe I fixed the problem on my own for less than $50. Its a good day.
Posted on Mar 15, 2009
Mrgomes is there a way to purchase some of those caps off of you? I can't find anyone who has them in stock. Send me an email: john3012 at yahoo dot com. Thanks
Posted on Aug 07, 2009
  • 1 more comment
  • john3012 Aug 10, 2009
    we need caps! See above.
  • john3012 Aug 17, 2009
    Ashmouth and cluxdelux are right! PCE3750CT-ND works. Thanks! I just
    got my caps soldered in and this free TV is awesome. I spent a total
    of ~$42.00 on repairing this 42” plasma. $9.95 on caps and shipping
    from Digikey, $16.77 on a candy bar, antistatic gloves and bags, and
    $15.89 on an 18 pack of Coors Light for the guy I found to solder it.
    If you **** at soldering and want to find someone to do it in your
    area, go to the SMTA website, find corporate members in your area and
    contact them in regards to SMT rework and repair services. It worked
    for me! I have 10 panasonic caps if anyone is interested?
    Previous comment posted my john3012. See contact address above in regard to caps.
We had the same problem with our Philips 42 inch plasma TV. The whole red blinking light problem that everyone talks about. I was ready to put the TV in the garage and try and figure some way to get rid of it when I decided to call Sears. Sears came out and replaced three blown capacitors (probably less than $15.00 worth of parts) for $220.00. At least the TV is fixed and didn't become a garage ornament.
Posted on Mar 17, 2009
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Nov 04, 2016 | Samsung Televison & Video
I have a 50" plasma Philips tv 50pfp5332d/37 it
Most Common problem is Bad Capacitors on the power supply board, they will be vented or swollen on Top. 1000uf 16v 2200uf 10v 3300uf 10v
Jun 25, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
I have had my TV-- a 42" Philips plasma-- for
it can be a poor contact or puffed capacitor in the power supply board
Dec 06, 2010 | Philips 42PFP5332D 42 in. Plasma...
My 50 inch philips plasma tv wont come on. all it does when you turn on the power is that the blue light comes on like usual and you hear a relay click and then a few seconds later you hear a relay clickin...
There are a few common gotchas for all plasma TVs:
Most commonly, a sustain board overheats and burns out; sometimes that prevents the TV from powering and sometimes it does not.
Unfortunately I don't know enough about your particular model to tell in which category it falls.
Second, the power board either breaks too (sometimes as a result of a sustain defection) or filter capacitors on it dry out and prevent the board from powering on properly. This, in turn, is detected by the protection circuits on the power board itself and treated as a short circuit, thus shutting down the board to prevent further damage.
In my experience 80% of the time the problem you describe is caused by burned ZSUS board and 20% are due to defect power board.
As I said earlier when a sustain burns out it sometimes takes down the power as well. Which is to say do not presume that just one board has gone bad.
One of these days I am planning to post a DIY troubleshooting guide for plasma TVs at my site http://www.coppelltvrepair.com .
It's easier than many people think.
For example in your case I'd try to power off the ZSUS board - the one on the right side of the TV when you watch from the back - and turn it on again. If it powers on then the problem is in the ZSUS board.
In fact, there are quite a few such guides circulating around the net.
The problem ,of course, is that it takes time to understand and apply them properly.
Unless you have a lot of time to kill or a desire to enter the field of TV repairs it's usually better to just pay off a good technician.
Developing the qualities to find a good specialist is a challenge well worth the time and will pay many times in life.
The same can not be said very safely for the qualities of repairing plasma TVs :-)
Jan 13, 2010 | Philips 42FD9932 42 in. Plasma Television
Power button comes on but no sound or picture
change the resistor in the relay circuit as they go high in value
also when you take power supply panel out check all caps for bulges etc.
Aug 26, 2009 | Philips 42PF9431D/37 TV
Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
42FD9954 philips plasma TV flashing LED it wont come on
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Nov 08, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Power issue
The Philips Plasma TV have a problem with electrolytic capacitors going bad. I believe you heated some capacitors and your problem may return. If so, try replacing 2540 (100ufd@25v)
and 2508 (4.7ufd@50V).
Apr 11, 2008 | Philips 42FD9954 42 in. Plasma HDTV
42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Jan 03, 2008 | Philips 42PF9956 42 in. HD-Ready Plasma...
Philips 42FD9954 42 in. Plasma HDTV Logo
9,433 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
