Question about QMark LFK304 Fan Forced Wall Heater - Perfect for Offices
K 484A fan forced wall heater
Heater has stopped working? i checked reset button and fuse and all appears ok
  • 2 more comments
  • Theodore Cain Oct 14, 2008
    was working yesterday, tried to turn it on today and not working at all. I turned it up all the way and no sound at all. before this happened i could hear some noise and it would turn on right away. now nothing???
    and yes it is on a circuit breaker
    just purchased this heater about 6 months ago. had professional install it.worked great until now,checked reset button ok, checked circuit breaker and everything appeared fine. as for plug and external wiring i dont know? how do i check this?
    I can see the connectors and all appear to be connected. any other solutions?
    Sergeant:
  • 352 Answers
Hi ratuted,
I was unclear as to your units power supply, if it plugs in pull plug and plug in hair dryer or some other small apppliance to verify circuit power. We'll continue if this isn't not the problem.
anaanymous - Union electrician 20 yrs exp. we'll get going guaranteed.
Posted on Oct 14, 2008
  • anaanymous Oct 14, 2008
    p.s.
    If the ciruit is dead recheck all the breaker, sometimes a tripped breaker may look as if it is still set. To narrow the search for the tripped breaker look at the panel legend and see what breaker controls that part of the house. Turn off all possible breakers one at a time fully turning off and then fully on. You may have to reset a few clocks in the by doing so, no problem, your not going to hurt anything just power off things like PC Tv's. Don't worry about the frig and stuff, they will be ok. We'll continue if this isn't the issue. Toubleshooting electrical problems requires a certain amount of patience.
    anaanymous
    Brigadier General:
  • 6,966 Answers
It would seem that diagnosis would have to be done by process of elimination. To start with, it has to be established that the unit is receiving power. This could be performed with the use of a voltmeter/DVM. Thereafter with the same tester, voltage checks should be done from the breakers, wiring, connector, fuse, switch, controller board, thermistor. thermal cutoff, heater element and fan. Since as you posted no sound, nothing at all, then initially, it could be assumed that the defect is common to the components such as missing power, either from the source or through the controller board. This would require familiarity with electrical components and circuitry. If you would be uncomfortable performing a DIY (do-it-yourself), perhaps the safest bet would be to seek the services of a qualified professional.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 51 Answers
  • There will be four deep hidden screws on the back.
  • Remove the screws and pull off the back.
  • The element connections are push on spade connectors.
  • See if one of your came off. Just push it back on its terminal and it should work
  • it will surely work.......
  • 19,396 Answers
Check the circuit breaker.
Try turning off power from main for fifteen minutes, and see if it restart when you put power back on.
If the unit does not show any sign of life (no power at all) then look for a circuit breaker or a fuse to be replaced.
    Genius:
  • 1,550 Answers
  • See if one of your came off. Just push it back on its terminal and it should work.
    Guru:
  • 558 Answers
You need to check its plug and external wiring.. may be worn out.
  • Puneet Jain
    Puneet Jain Oct 14, 2008
    Its power controller and Switches need to be check internally, if you are capable to open them with the help of screw diver and other tools.
    The supply power wiring and the internal wiring to power controller may be broken up.
    Go through this site and if you dont have manual then use it and check out :
    http://www.heatersplus.com/ceiling.htm
    Have a Nice day
    Regards,
    Ellin
I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Stopped coming on. Checked breaker, CFI in b'room, etc. Took grill off, nothing apparently loose or disconnected. 18 months old. Any ideas to try b4 calling electrician? Jim @ 828-230-0077
This 120V / 12A heater *requires* the full capacity of a 15 amp circuit - which means it must be on its own 15 amp circuit and not added to any other 15 amp (outlet or lighting) circuit.
Double check for a circuit breaker in the tripped or off position (or blown fuse). Reset and turn on (or replace fuse) as needed. If circuit breakers and fuses look OK - it may be a faulty heater, thermostat, connection, etc.and calling an electrician might be the best and safest solution.
Oct 23, 2015 | QMark CRA1012T2 Fan Forced Wall Heater -...
Replaced failed circular element in main oven. Still not working and code 555 displayed when power turned back on
Make sure you have 220 volts at the wall plug for the oven. If not try resetting the circuit breaker for it. You may need to replace the breaker if it is several years old.
Jun 22, 2015 | Ovens
I have a prolectrix wall mounted bowed fireplace model BG-D4. The fan quit working and now it overheats and shuts down. Is there a fuse or a reset button?
I don't know this specific product but if it is designed to run with the fan, it will overheat if the fan stops and shut down. Often, the shut down is by a thermal cutout, so just wait for it to cool dow.. You may have to remove power.
Jun 23, 2014 | Heating & Cooling
My new rieker fan stopped blowing heat- the fan works --not the heater
I had the same problem with my fan and solved it with a reset. The reset button is on the back of the remote next to the dip switches. You have to take the battery cover off to see it.
Turn on the fan with heat, even though the heat doesn't work. Then, leaving the remote on, turn off the fan at the wall switch (or circuit breaker box). Wait a few minutes. Then turn on the power and within 30 seconds, press the reset button. You should be able to see a countdown from 5 to 0 on the remote screen.
Once I did this the heat started working again.
Jan 05, 2011 | Reiker Ceiling Fan/Heater Combo Utility
2001 Volvo v70. The heater/ac fan has stopped working. I have checked all fuses. Can suggest what my next step should be?
The fuse for heater/ac fan is number 36.30 amp located end of dash
If this is ok,you need to replace heater control module behind heater controls.Save money buy haynes manual,check e bay
Apr 09, 2010 | 2001 Volvo V70
The heater blower motor on my 2001 ford crown vic won't work. i checked the fuse and took the motor out and had it checked and it's OK.
look for relay or resistor heater box under hood passenger side follow heater hoses 2 two heater box coming out of fire wall
Jan 25, 2010 | 2001 Ford Crown Victoria
Cadet wall heater
Since I don't know what model of heater you have there might be a reset button to reset or an over temp switch (button sensor with 2 wires going to it) that needs to be replaced. You might check the recall list to see if this one has been recalled and should not be used.
Sep 11, 2008 | Heating & Cooling
QMark LFK304 Fan Forced Wall Heater - Perfect for Offices Logo
228 people viewed this question
Top QMark Heating & Cooling Experts
Paul Carew
appman67
appman67
john h
Are you a QMark Heating and Cooling Expert? Answer questions, earn points and help others
