Question about Dryers
My Indesit IS70 tumble dryer is not venting properly. Water build up in the base of the machione, behind the condenser, and does not make its way to the water holder at the top of the machine.
    President:
  • 1,462 Answers
There is a hole for the water from the condensor to the water collector. make sure it is not blocked - this is common to happen.
take small panel off at back of machine and you can see the water collector. it has a small pump mounted on it which takes the water up to the top of the machine.
connbect this pump independently to mains and make sure it is pumping
Posted on Oct 14, 2008
  • spear1 Dec 12, 2010
    Small hole, more like a slot on the left hand lower side of the water collector (on the back of the tumble dryer!). Probably best to remove the condenser from the front and get your arm inside and clean all the wet fluff from the other side of the water collecter to avoid it blocking again!
My indesit condenser tumble dryerwont start
try door interlock......................cheers
Oct 07, 2016 | Indesit Dryers
Tumble dryer eeps tripping electric
Had same problem found a lot or water at the rear of the condensing element at bottom front of dryer because the float at the rear was blocked with fluff resulting in water being flicked up by the fan onto the heating element and tripping the electric. Cleaned out float compartment and been fine up til now. For a quick fix (UNPLUG FIRST) remove the condensing element at the bottom front of tumble dryer(behind the drop down cover) then carefully tip the dryer forward and to the left so that it practically balancing on the front left corner, you will probably get a fair bit of water come out so have some towels ready, then dry as much as you can see inside the compartment then replace element and should be good for quite a while until you have more time to clean out the rear compartment. Hope this helps, let me know.
Feb 11, 2014 | Indesit IS70C Electric Dryer
Tumble dryer not drying properly
Make sure your dryer vent is clean. This can get clogged with lint over a period of time. Make sure to check both inside and outside vents
Dec 23, 2013 | Indesit Dryers
I have an indesit IS70 SC tumble dryer which is very noisy. The noise appears to be coming from the air intake fan and sounds a bit like a piece of cardboard against bicycle wheel spokes. Any ideas?
Dryers are not hard to take apart.
There is possible something caught inbehind things.
Make sure to unplug the dryer first. Then proceed to take it apart carefully noteing thing as you do it, so that you can reasseblem
Jan 12, 2013 | Indesit IS70C Electric Dryer
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Aug 21, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Not drying clothes
If the unit is heating properly which it should pull around 25 amps when heating , and the unit is tumbling it is 100% an exhaust issue , either a kinked duct behind the unit , a ball of lint stuck in the duct , lint build up outside in vent , or water in under ground duct. If you find the clog it will be FIXED!
Let me know if you have any other questions.
Phil
Apr 14, 2009 | Whirlpool WED6200S Electric Dryer
I have to use my indesit condensing tumble dryer about 3 times to get 1 load to dry
Hi.
Make sure the fluff filter and water tray are clean and empty.
Also make sure it is on High heat setting, and set the correct time.
Nov 28, 2008 | Dryers
Indesit is70 tumble dryer
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 06, 2008 | Indesit WA 125 Front Load Washer
Dryers Logo
139 people viewed this question
Top Dryers Experts
