Question about Hotpoint Washing Machines
I have an Hotpoint Aquarius washer dryer WD61.I moved my machine from one house to another in the car but led it on its side.After it was re-installed the washer worked fine until it come to pump the water away.We took the hose out of the waste to drain it and it spun perfectly.Could you let me know what the problem is and how to remedy it please/
    President:
  • 1,462 Answers
Take bottom panel off at back. there is a large diameter hose going from the bottom of the tub to the pump. disconnect this hose at the tub end and you will find the filter inside (carefull, water may come out)
also, put onto drain program and check the pump is actually turning
also
if drain is connected to a spigot on the sink trap, this spigot may be blanked off if iot has never been used
Posted on Oct 14, 2008
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
Water leaks from powder drawer on my hotpoint aquarius washer drier WD61 why
Machine may be leaning forward slightly, try lifting the front end by adjusting the front feet.
Feb 24, 2010 | Washing Machines
I have an Aquarius WD61 washer/dryer. The door will not now open.
No date on this that I can find. Can you move the dial to a different setting? If so, just move it a fraction to see if it will engage. If it does engage, then you will need a new timer, goes under the dial. If it is a computer panel, try resetting it on another load setting and put it on the final spin.
Godd luck
Aug 08, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Model WD61 Washer Dryer working but it's noisey
If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine)
Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner).
If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
Update me about your progress
Good Luck
May 19, 2009 | Hotpoint Aquarius WD63 Front Load...
Working but making noise when spinning.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion....
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Machine keeps tripping the fuse at the fuse box - WD61 Aquarius Hotpoint
I believe the problem is in the fus(breaker). I would say that it is the thermal fuse in the machine but it usually goes out before the breaker does. The breaker has gotten weak over the years. You have a hi limit on the machine as well but I doubt this is it. Let me know how you do.
Feb 07, 2009 | Hotpoint Dryers
No manual how to use thei machine
Try this website may be helpful to you in finding the Manual:
Hotpoint Front Load Washer
Best of Luck Scott
Jan 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
146 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
