Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Dish washer over filling?
Hobart dishwasher over fills with water and leaks out the door.
  • Anonymous Mar 25, 2014
    Hobart ecomax500 dishwasher does not fill up water
    Scholar:
  • 112 Answers
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Posted on Oct 18, 2008
LXI H, leaks out around bottom of door only when unit has not been run for a couple of days and hold water in washer after use. Error Code E7 what does this mean
Posted on May 19, 2009
Hi I have a Hobart LXIH dishwasher and it is leaking water out of the bottom corners of the door. Do you know what might be causing this?It has a seal at the top but no seal on the sides or bottom.
Make sure your rinse wash arms have the end plugs. If one is missing, water will spray out door.
Your fill valve could possibly be malfunctioning, therefore not closing all of the way. I used to work for Hobart. These LX machines can be a pain in the rear. If you have a water softner, then the valve is probably functioning normally. I do not recall it ever being the door gaskets. I would think you should be getting an error code with the wrench. This is a hot water machine. If you have lime scale building up inside, you may try deliming it. The drain valve could be also causing a problem. There are so many things it could be.
Oct 16, 2017 | Hobart Dishwashers
Hobart sr24c is leaking water out the bottom of the door during operation.
You have a bad seal try replacing the gasket make sure your drain so not clogged up to ensure proper water drainage
Apr 21, 2016 | Hobart Dishwashers
My hobart dishwasher am 14c will not go into cycle
Check the Door switch. If the screen shows FILL but don´t do it, check all fuses on control board.
Apr 09, 2010 | Hobart 29 in. AM15-1 Free-Standing...
I have sr24c that leaks water at bottom of door . how do i fix it? their is no door seal.
first make sure the unit is tipped back higher in the front. also ck. incoming water pressure with fill soleniod open should be 20 p.s.i
Jan 06, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart dishwasher leaking as it rinses/fills
If the brand is Watts, a rebuild kit is available from Hobart. Their part # 118270. It should contain the float with a red rubber gasket and a bonnet o-ring. Unscrew the cap, clean off the sealing surface and drop in the new float OR you might find a local Watts distributor and see if they carry the kit. That should solve the leaking issue. Let me know.
Oct 29, 2009 | Hobart AM14C-155 Dishwasher
My dishwasher is not filling up water to start the washing cycle when the door is closed
Asuming you have an AM15, Check you have power to the fill valve during fill cycle. Make sure your drain is closed to retain the fill water. You should have 20 psi flow rate.
Jul 19, 2009 | Hobart 29 in. AM15-1 Free-Standing...
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX15H indicates E4 and will not fill.
This is what I found in the manual...and on a couple of other sites....
OFF-ON procedure.
5. Delime machine.
If this doesn't help let me know and I will get to the bottom of it....good luck and thanks for rating my effort...The Fang.
Apr 27, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
780 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
