Question about Samsung NV3 Digital Camera
Problem with Samsung D860 camera
I am having aproblem with a digital camera. (Samsung D860).
I just took a series of photos and then uploaded them onto my computer. I plogged the camera into the computer with the lens still out. After I uploaded the photos, I unplugged the cable and now the lens is stuck out and upen. It will not switch back on into camera mode. I have replaced the batteries and memory card. The power light comes on briefly but the camera willnot respond. The battery power was full when the camera last switched (10 minutes ago).
Can anyonbe help?
Thanks,
Matt.
  • 2 more comments
  • jojiali Nov 18, 2008
    exactly the same problem... i urgently need help coz i was using some on else`s
  • Anonymous Jan 21, 2009
    Same, turned it on and screen went blank now the lens is stuck out and cant turn on again:(
  • Anonymous Jan 28, 2009
    Exactly the same problem. Green lights comes on if you hold the power button, but no activity on screen.
  • Anonymous Feb 22, 2009
    same as the above took one pic then it froze up with the lens still out and now the lens wont go back in and the camra will not turn on
5 Suggested Answers
SOURCE: Samsung s850 cant copy from camera to sd card?
The Samsung S850 has an internal feature to do this. I have one. Put in your memory card and turn on the camera, push the button on the bottom right hand side of the lcd screen to view the picture, next when you see a picture (it can be any picture) push the OK button, this brings up a set of commands across the top of the screen, as you go across the commands one of them will be "copy to card". Select yes and the camera will copy the pictures to the card.
Posted on Jan 12, 2009
SOURCE: camera wont turn on
How I fixed my Camera:
> First take your Memory card off, and remove battery
> Now, leave your camera without battery-power
=(wait for while!)
>Then,start your camera WITHOUT Memory-Card.
Note: MiniSD Card with adapter, may crash/freeze camera.
(so use the real "one piece" SD-card, not that Micro-thing!)
>When i removed the old SD card, everything was OK.
I hope this can help many others?
GonaOne from Finland.
Posted on Mar 26, 2009
SOURCE: Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
Posted on Apr 23, 2009
BillB-SA
  • 2761 Answers
SOURCE: Hi, my Samsung nv10 camera, when switching on,
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Posted on Sep 14, 2009
  • 11967 Answers
SOURCE: camera turns on briefly then off
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 20, 2010
I have a samsung s860 camera does the camera save photos in memory or only in the card
Hello Marina Mae,
Samsung S860 has 11 MB internal memory.
I hope this helped you.
You can rate my answer if you appreciate it.
Thanks!
Oct 26, 2011 | Samsung S860 Digital Cameras. 8-megapixel...
Hi my samsung d860 digital camera flash is not working
does any one know if there is a mains charger ( 3 PIN 240V ) for a samsung d860 digital camera and if so where to get one ?
Nov 11, 2009 | Cameras
How do i dowload software for samsung D760 digital camera
From the Samsung website! Drivers and software for electronics is kept in the Support section of the manufacturers website.
In your case, that particular camera doesn't show up on the US, Canadian, or UK sites, so I would suggest trying the software for the D860 on the UK site:
http://www.samsung.com/uk/support/download/supportDownMain.do
Aug 13, 2009 | Cameras
Have lost instructions for Digital Camera D860.Please can I download a new set?
Thanks for your interest.I do not need your help now because I did actually find the booklet of instructions that I had lost.Miracles do happen !!
Jenni
Aug 04, 2009 | Samsung Cameras
Downloading Images from Camera to laptop
Your camera may not be compatible with Windows Vista. What I would recommend doing is getting a separate card reader, and when you want to download your photos, you have to take the memory card out of the camera and put it in the card reader. Then you can see all the photos on the card as if it were a normal folder on your computer.
Jan 06, 2009 | Cameras
Olympus FE310 Series, Battery Problem
Hi, I have had the same problem with the battery not working.  I have changed batteries several times, with no change.  I bought the camera when I was pregnant so I could have a camera in my bag to take spontaneous photos of my baby but was disappointed at the birth and ever since because the battery is not dependable! I took it into the shop and was informed there could be a $90 charge if there is no mechanical problems... :-((
Jul 31, 2008 | Olympus Camedia Stylus 300 Digital Camera
D70 camera
you need to use PTSH or special softwares that can read naf files
usually it's very big files. do you have enough memory on ur computer';?
Jun 27, 2008 | Nikon D70s Digital Camera
Samsung NV3 Digital Camera Logo
77 people viewed this question
Top Samsung Cameras Experts
Kirk Augustin
Kirk Augustin
Are you a Samsung Camera Expert? Answer questions, earn points and help others
